Old 07-06-2011, 09:26 PM   #1
First66
First66's Avatar
Tail Light Issue
I recently bought a set of tail lights from Classicparts.com and my wiring is off and I dont know where to start. I searched the Electrical section of the forum but most, if not all threads are of post 67 trucks so I figured someone here might be more familiar with the problem.
http://www.classicparts.com/1960-66-...ctinfo/49-132/
Turns signal function is the only one that works. When I pull the headlight switch, nothing, and when I brake, nothing. The new tail lights have an orange and black wire, and my truck has a four wires going back, all the same color. I used a spark tester to tell the Left and Right signal wires, but got nothing from the other two. Other than follow the faulty wires up to the cab, what else could it be?
1966 Step C10
First66 is offline   Reply With Quote
Old 07-06-2011, 10:06 PM   #2
padresag
Re: Tail Light Issue
how about your grounds
ron
padresag is offline   Reply With Quote
Old 07-06-2011, 11:36 PM   #3
JohnnyBoy350
I just went through the hell of taillight wiring and it was the ground in my case. Thats why the ground wire is always black- its EVIL!! Its ALWAYS the ground!! hahaha
If you look at where the taillight wiring goes through the firewall you can unplug it from the main harness under the dash. Thats where I started, tested the functions at the main harness. Just work you way back testing each part of the harness till you find the problem........which will probly be the ground hahaha. I couldn't even get my test light to ground on that old rusty frame of mine, had to resort to a flap disc to clean it up.
-John
If it don't go, chrome it!
JohnnyBoy350 is offline   Reply With Quote
Old 07-07-2011, 12:31 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
might sound dumb but I had ordered LED tails for my truck, and when I got them I wired them color to color as I expected. I turned everything on to find out the functions didn't work. I went back and noticed that each wire is labeled, and they do not follow "common sense" wiring. Black isn't ground, and they had 2 of the same color for signal and on.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-07-2011, 12:42 PM   #5
First66
First66's Avatar
Same here. Mine came with a two, one black and one orange; the orange is ground.
1966 Step C10
Old 07-07-2011, 01:07 PM   #6
fixit-p
fixit-p's Avatar
Red=Stop/Turn
Black=Taillight
If there is no other wire for ground then it is grounded through the mounting screws. Make sure the bed is grounded to the frame and ultimately the frame needs to be grounded to the battery
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 07-09-2011, 03:36 PM   #7
herumith
herumith's Avatar
I had a similar issue on my fleetside taillights. It seems that with any amount of rust on the frame, your grounds won't work since the mounting screws for the light fixture are the grounds.
herumith is offline   Reply With Quote
Old 07-09-2011, 05:10 PM   #8
First66
First66's Avatar
I got sidetracked with getting this crap bumper off, but will definitely be giving the lights a go again. I'll keep you all posted. PO didnt even attempt to build brackets for it, and it dented my fenders about an inch in on both sides...
1966 Step C10
