exhaust exit ???
does anybody have pics of side exit exhaust before or after the rear tire, that exits through the bedside/body?? also, where can i buy them as i am thinking of doing this on my burb??
p.s. thanks in advance |
Re: exhaust exit ???
MIght look at a marine supply business for the tips. Most should have a fairly decent collection of tips that are 'through the hull' design.
I'm also thinking about doing that. I keep bouncing around between doing one per side or trying to have them both exit on the same side.
My 72 Suburban Build - http://67-72chevytrucks.com/vboard/s...d.php?t=454019 79 Volvo Turbo LS Build - http://67-72chevytrucks.com/vboard/s...d.php?t=594252 Buggy Bed for son - http://67-72chevytrucks.com/vboard/s...d.php?t=657350 |
I found these two and a couple other variations (http://www.stylintrucks.com/category...aust_tips.aspx). Not sure if this is what you're looking for or not.
Dig this one. I plan to do the same soon.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
#7 | |
that looks good, and i had my exhaust like that at one time, but it will no longer work like that for me
![]() mine goes to low for that to work |
I would just make them yourself. They charge a good chunk of change for them and I think its doable.
Yeah, still haven't put truck to screen name. As far as the too low thing...don't rub it in
haha thanks lol.
edit...
oops wrong thread ![]() |
#13 |
Man I like that whole truck there
Posted via Mobile Device |
#14 |
Old Skool Club
![]() Join Date: Jun 2001
Here's one...
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#15 |
any others out their?? i have searched but came up empty handed for pics of 67-72's with side exit exhaust through the bed/body
#16 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Not sure who makes these?????
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#17 |
the boat guy
crownline makes a nice side exit exhaust for some of their boats. I try ebay or boat salvage. http://www.crownline.com/2011/models...s/lpx-package/
#18 |
#19 |
I agree it looks cool, but be careful what you wish for. My exhaust exits in front of rear tires about three quarters of an inch under the body and I am already noticing discoloration. Looks cool sound cool (actually quiet, for long tube headers and flow master super40's) but I have a feeling it could easily turn into a problem, and I'm not even going through a body panel. Just some food for thought. Tim
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. " |
#20 |
Old Skool Club
You'd have to provide some kind of isolation material to connect the exhaust pipes to the trim that is attached to the body. I'm thinking that the part that passed through a body panel, would ultimately damage the paint and/or the body. I could be wrong, tho. It's just my opinion.
#21 |
IF i decide to do it this way, i may just have to make my own, but if i do, it will probably either be flush, or stick out past the side of the body just about a 1/2". also, it will have some sort of flex pipe if it is hard mounted to the body
#22 |
exiting in front of my tires....no problems,running this for over a year.
#23 | |
#24 |
PROJECT 7DEUCE
That is not mine I stole the pic off this board from somewhere???
#25 |
