Old 07-07-2011, 11:21 AM   #1
72TealnWhite
72TealnWhite's Avatar
Gasoline?
Hey all, was wondering what type of gasoline you all like to run in your trucks ... 87 89 92 ect... Do you choose to use the more expensive or mid grade over regular.. And have you noticed any difference in performance.
basically .. are there any benefits to putting in mid or high grade gasoline ... for performance and maintainance ?
thanks ..
nate
72TealnWhite is offline   Reply With Quote
Old 07-07-2011, 11:35 AM   #2
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
Re: Gasoline?
No benefit to higher octane unless your truck/vehicle has high enough compression to require the more expensive fuel. On a basic truck, the 85/87 is adequate. Running the higher stuff will not give you any benefit other than a thinner wallet.
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 07-07-2011, 11:40 AM   #3
mpotts64
mpotts64's Avatar
Re: Gasoline?
I run regular, no ethanol in everything. I have found I get about another 60 miles a tank as opposed to the other.
No one ever fell to the top of a mountain.
When asked why I work on old trucks, I tell them: Been married 27 years, sons are pretty much gone, don't like the wife anymore and don't have a girlfriend, so, gotta do something, the old trucks are cheaper and less drama than a girlfriend -
mpotts64 is offline   Reply With Quote
Old 07-07-2011, 11:58 AM   #4
stich626
Re: Gasoline?
run 87, 89 if running up the white moutains..
stich626 is offline   Reply With Quote
Old 07-07-2011, 12:42 PM   #5
flashed
Re: Gasoline?
I run regular in all ours ,I just wish non ethanol gas was available around here .My mileage suffers greatly with the ethanol blend.
flashed is offline   Reply With Quote
Old 07-07-2011, 12:44 PM   #6
flashed
Re: Gasoline?
The ethanol blend also causes all kinds of problems with small engines such as weed eaters ,chainsaws and small mowers.
Old 07-07-2011, 12:47 PM   #7
stich626
Re: Gasoline?
add gas stations storage tanks to that list.. and the epa is going ahead with e15..
fuel prices are gonna go up as the tanks life is halfed
Old 07-07-2011, 08:01 PM   #8
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Gasoline?
I did a number of checks in my company trucks (newer EFI stuff) and did it the only way that makes sense,, Cost per mile for fuel.
When fuel was $2.50 a gallon my 04 and newer vehicles were more economical to operate on 89 octane. Now that it's $3.50 a gallon I should check everything again, but I be the trend holds true.
Instead of dividing the miles driven by gallons used, ,,, divide the $'s to fill up by the miles driven. Try it with all 3 pump grades, and even different stations and you'll find the one most economical for your particular use. The motor (and the cost) will tell you what it likes.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 07-08-2011, 12:08 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Gasoline?
High compression, High RPM, High HP... 92 octane for me.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-26-2011, 03:54 AM   #10
Fullpower
CHEAP gas
I run 87 octane in all of my (gasoline )engines.
The cheepest swill I can find.
Even the motorcycles like 87 octane just fine
Fullpower is offline   Reply With Quote
Old 07-26-2011, 03:47 PM   #11
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Gasoline?
cheap lowest 87 for me ,4.00 gal and one can of booster ,im glad my engine runs on this stuff ,racing fuel is outragous but i love the smell
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-26-2011, 06:37 PM   #12
crazy longhorn
Fabricate till you "puke"
Re: Gasoline?
92-93 in the Longhorn & the Harley(both high comp engines)....I run 89 in the 02 Silverado, as well as the wifeys 09 Honda CRV. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
