steering wheel removal 72
can't imagine it is too hard.... what do I need to remove the stock steering wheel from my 72. Do I need a puller. Also how difficult to replace with an aftermarket wheel and what do I need. Is there a kit..... any tricks or things to look out for...
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
Moderator
![]() Join Date: May 2007
Re: steering wheel removal 72
This set pictured runs about $10 at harbor freight and will pull your wheel and many other things as well.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
i have had look by just pulling the wheel it put up a little fight but it came off sometimes you may need a puller if you dont have one get a mallet wood or rubber and give the back of the steering wheel some good taps and it should break free, as for wrench size i dont rmember the correct size its a 13/16ths i think but can t be sure you will also need a phillps screw driver if your using a puller to take it off
i just loosen the nut then with my knees behind the wheel appling pressure i lake my 2lb hammer and with the end of the handle give a sharp blow on the nut and the wheel pops loose
Having just recently changed out my 69's wheel,I was able to wiggle it back/forth and remove it w/o a puller.Seems like a straight pull or tapping with a hammer did nothing.
so seems I will try with out a puler first. then get the kit for the wheel i want. once I have that its pretty much install the wheel. do they need to be torq to any specific spec.
Man of Mini-Talents
Your local auto parts store will rent a puller for free.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#8 | |
![]() Here is what I went with,4 spoke out of a vega????????Horn button took alittle patience but thanks to help here I'm honking away! |
hmm thay vega wheel looks good. wonder if i could find at a wrecker place
Hey be careful if you just start pulling on it...sometimes they will fly off and hit you in the face
