Old 07-07-2011, 08:45 PM   #1
RandyDandy
Just swapping the control arms
Did i read here somewhere that i do not have to change the crossmember in my 66 to put the 73-87 control arms on, and all you have to do is drill out the u- bolt holes that hold them on because 73-87 are bigger.
RandyDandy is offline   Reply With Quote
Old 07-07-2011, 08:52 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Just swapping the control arms
That is true.
The upper arms bolt straight on.
The lower arm u-bolts are larger so you must pass a drill bit through the holes in the crossmember to enlarge them. After that, they bolt on.
Old 07-07-2011, 09:25 PM   #3
RandyDandy
Thankyou sir for the reply, i thought i read that here somewhere.
Old 07-08-2011, 06:12 AM   #4
badblu97
Double 6's
badblu97's Avatar
You could keep your stock arms and put 73-87 balljoints in....thats what I did...
Street Glidin!
1966 LWB Custom Cab (sold)
1982 Short Fleet (under the knife)
1998 S10 2wd Fleet
2007 Chevy Silverado Crew
2007 Harley Davidson Street Glide
badblu97 is offline   Reply With Quote
Old 07-08-2011, 06:59 AM   #5
PGSigns
PGSigns's Avatar
You can also reuse your old ubolts and put on the newer lowers. I used a die grinder to do mine. The holes need to be bigger but they also need to be further apart. When I tried to drill them the bit kept trying to follow the old hole.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-08-2011, 10:14 AM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
I used the 65 u bolts. Just bolted in the control arms and used everything else from a 75 truck. Just have to redrill for the idler arm.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-08-2011, 03:45 PM   #7
sinnersahuayo
i have a question why do you change the control arms on the truck. my truck is a 1965. i just want to know more info on this; the ball joint or arms.
sinnersahuayo is offline   Reply With Quote
Old 07-08-2011, 05:09 PM   #8
lil_sahara450r
its a fairly common swap. instead of spending big $$$ on a kit, you can swap over the entire crossmember (or just the a arms out, or even just upgrade your ball joints and use the spindle) from a 73-87 c10. advantages are 5 lug disk brakes and beefier steering components.
lil_sahara450r is offline   Reply With Quote
Old 07-08-2011, 06:06 PM   #9
sinnersahuayo
thanks i didnt know that.
Old 07-08-2011, 11:23 PM   #10
RandyDandy
I am going to be buying dropped spindles and springs but i want to change the control arms for the rubber bushings in the 73 -87 arms. Thanks for the replies.
Old 07-09-2011, 12:08 AM   #11
Captainfab
60-66 Nut
Here is some reading for you......
http://67-72chevytrucks.com/vboard/s...d.php?t=367260
There are several threads with good info listed in the '60-'66 FAQ Index at the top of the main '60-'66 page
Old 08-02-2012, 09:03 PM   #12
AKNIKLS
AKNIKLS's Avatar
hows it goin. i have a 62 c10 half ton. i bought a crossmember and front suspension from a 65 to escape the torsion bar suspension. can i just replace the a-arms on this as well? thanks-aaron
AKNIKLS is offline   Reply With Quote
Old 08-02-2012, 09:19 PM   #13
CRGRS 66
CRGRS 66's Avatar
I have not placed my order yet, but will be buying the "expensive kit" from Scott's Hot Rods (vendor on here that is highly regarded). I don't think it is expensive at all. for somewhere around 650ish you get drop spindles, rotors, bearings, calipers w/pads, hoses, all hardware, and brake booster MC c/w prop valve. Cheaper than a brake job at the shop... Re-bush your control arms, save a few $ there too. When you go this route, you aren't creating an issue where you have a 65 truck with 73-87 this and that. Ask McMurphy, he forgot mid install that his cross member etc were not original and ordered the wrong ball joints, poor guy had a melt down that day. If you sell the truck, and that guy sells the truck, the new owner will cursing the PO when he is replacing something, and finds that the 60's parts won't fit. Just my thoughts, many ways to skin a cat (have always wanted to do that too), it is your cat, you skin it your way, cheers!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 08-02-2012, 09:22 PM   #14
CRGRS 66
CRGRS 66's Avatar
I plan to do a power steering swap this winter too, have heard nothing but props for captain fab's kit, so will be supporting cap in the not too distant future too. Sorry, little off topic, but wanted to plug another board vendor.
Craigerrr
Old 08-03-2012, 11:47 PM   #15
Captainfab
60-66 Nut
As long as the '65 front suspension is from a C10, you can upgrade that how ever you wish. You can use those control arms and just change the ball joints and add disc spindles, calipers, rotors, etc. Or you can also change the control arms to the '73-'87 arms with the rubber bushings. Either way, I always recommend changing everything from the same vintage of truck. If you use '73-'87 spindles, I recommend changing the complete steering linkage, as well as the steering box, from a '73-'87 truck. If possible stay close to the same year for all parts. This makes parts replacement easier down the road as mentioned above. When building a truck or car, that is no longer stock, it is a good idea to keep a record of the parts used and/or the part numbers for future reference.
Old 08-04-2012, 12:12 AM   #16
badriand
badriand's Avatar
I didn't drill out anything just just took upper and lowers off 87 suburban and bolted them right up to mine. Biggest issues had was digging 20+ yrs of dirt and grime away from u bolts to get to nuts.
badriand is offline   Reply With Quote
Old 08-04-2012, 12:32 AM   #17
Captainfab
60-66 Nut
I always recommend upgrading to the larger diameter lower control arm U-bolts used on the '73-'87 trucks. I have had 2 of the smaller original U-bolts break on me. I was lucky and no serious damage or injury resulted.
Old 03-07-2016, 09:11 PM   #18
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Will 73-87 upper and lower arms bolt up to a 62 crossmember?
66 C20 Service Truck:
Old 03-08-2016, 01:04 AM   #19
Captainfab
60-66 Nut
No they will not.
Old 03-08-2016, 11:25 AM   #20
chevy_mike
Never Ending Projects
chevy_mike's Avatar
60-62 are torsion bar front ends. Completely different than 63-87 coil spring setup.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-08-2016, 11:38 AM   #21
LostMy65
LostMy65's Avatar
Yeah, I understand they have torsion bars.
I was just wondering if the 60-62 Lower and Upper arms could be unbolted and replaced with 73+87 arms without removing the whole crossmember.
Thanks, now I know.
Old 03-08-2016, 11:41 AM   #22
LostMy65
LostMy65's Avatar
Now I remember. The 63+ crossmembers have a pocket for the coil springs.
Old 03-03-2021, 10:42 AM   #23
lowroder
Originally Posted by Captainfab View Post
No they will not.
Confused....
Previously mentioned.
It was said you can swap out the control arms on the 62 .
Then said you can't?
I also have a 62 looking to eliminate the torsion setup an go disc brakes an lower it .
Was also interested in just swapping out the upper and lower arms or just the lower...
From 63 to 66 or newer.
lowroder is offline   Reply With Quote
Old 03-03-2021, 11:15 PM   #24
Captainfab
60-66 Nut
I believe what was discussed in post #15 was swapping the '73-'87 control arms onto a '65 C10 front suspension, not the '62 suspension. The '60-'62 front suspension is completely different than the '63-'87 suspension and you can not just swap control arms.
