Old 07-08-2011, 07:06 AM   #1
Edmond
Edmond's Avatar
Shift Lever for tilt column
I had this aluminium shift lever in the addict for a few years and I thought today well why not put it in. So I took the standard lever out and noticed that they look totally different.
But looking online it looks like the one I have, and yet the one I took out looks not like it.
It looks the wrong way round to me...
Is the aluminium one the right one for a Tilt column?
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
The Netherlands
Edmond is offline   Reply With Quote
Old 07-08-2011, 11:30 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Shift Lever for tilt column
The aluminum shifter is for a later model truck column, and most '69 and later car columns, not for a '70-'72 truck or pre '81 van.
ls1nova71 is offline   Reply With Quote
Old 07-09-2011, 04:04 AM   #3
Edmond
Edmond's Avatar
Thanks.
The Netherlands
Old 07-09-2011, 09:39 AM   #4
AirSpeed
AirSpeed's Avatar
Is that little hole on the aluminum lever a set screw? The hole down by the end that inserts into the column? They look the same if the steel piece was turned around, if that is a set screw maybe that steel piece turns to match the other lever?
AirSpeed is offline   Reply With Quote
Old 07-09-2011, 10:41 AM   #5
Edmond
Edmond's Avatar
No screw in there, but a pin you tab in with a hammer securing the parts together.
Been thinking about turning in around but the shape of the two are completely different so I didn't even tried it.
Cya,
Edmond
The Netherlands
Old 07-09-2011, 11:51 AM   #6
AirSpeed
AirSpeed's Avatar
Cya,
Edmond
They seem to have the same bends, the aluminum one has sharper bends but the are in the same general position. It couldn't hurt to tap that pin out and give it a try. The only problem I can see is the aluminum lever may come back too far and hit the steering wheel.
