66 shifter hump
I have a 66 that had a 4 speed. I have installed a big block with a th400 trans. I would like to have a lower hump what can I do. Please post pictures if you have them.
Thanks Keith |
Re: 66 shifter hump
If you have a donor truck w/a small hump they can be swapped but its not easy. Welder is required. I did it several years ago on my burb-you need the front piece up on the firewall also.
http://s210.photobucket.com/albums/b...leetside/burb/ in one pic you can see I had sheetmetal screws holding it in place, then I spot welded it all in place-once done it looks like it came that way-much more footroom also. My burb was 4 speed OEM, its 700r4 now. Last edited by 64fleetside; 07-08-2011 at 10:21 AM. Reason: typos |
Re: 66 shifter hump
the large hump bolted in the small hump is built in.....little harder to change.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 66 shifter hump
Some of the low hump covers were bolted in just like the large hump covers.
Re: 66 shifter hump
Captain
Do you know what year truck the bolt in low hump are in. I would realy like to find one. Thanks Keith |
60-66 Nut
Re: 66 shifter hump
As far as I know they were available in all years from '60-'66. I believe they were in the trucks with the 3 OTT?
#7 | |
1961 crewcab
Re: 66 shifter hump
seems like all the 60-63 1/2 ton 3 OT trucks were bolt in... most of the 456 lows I have seen are welded, but I have seen pics of a 456 bolt in low....
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
