Old 07-08-2011, 03:35 PM   #1
bimaldo
Grrrrrr
Greetings
has anyone expierenced the following?
I get in my truck and kit the key...it wont turn over.
wait about 4 hours
get in and hit the key vrooooooom - starts right up.
I've been scratching my head. This has happened to me a few times now and cant figure out what the deal is.
It happened when it was cold out (45°)
and yesterday when it was hotter (87°).
each time the truck had been sittting for a few days.
nothing special under the hood.
350/700r4
bimaldo is offline   Reply With Quote
Old 07-08-2011, 03:46 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: Grrrrrr
Your starter and solenoid have heat soak. Common problem with these trucks especialy if you have headers. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 07-08-2011, 04:01 PM   #3
rsavage
rsavage's Avatar
Re: Grrrrrr
+1 on what Wes said if your engine is hot (has recently been shut off). If your engine is cold, I would start cleaning every contact - battery connections, ground to block connection, connections on solenoid including positive from battery.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 07-08-2011, 04:34 PM   #4
Rob H.
Rob H.'s Avatar
Re: Grrrrrr
The way I read it it's when your truck has been sitting. I would start with checking all the ground locations, make sure the engine to body grounds are attached. Also could be the starter itself, I just recently had one on a Jeep do simular thing. Good luck with it.
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline   Reply With Quote
Old 07-08-2011, 04:56 PM   #5
Sammy
Re: Grrrrrr
On mine neutral safety switch wire wiggles a bit a little movement and it cranks right up.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 07-08-2011, 04:57 PM   #6
bimaldo
Re: Grrrrrr
thanks guys,
it only has happened when the truck has been sitting for a few days, so I think I may be able to rule out the heat soak starter.
Rob, when you say it could be the starter itself, I am not sure what you mean.
The starter turns the engine, it just wont fire.
I will start looking at the engine to fram grounds.
could it be a short sanywhere ?
bill
Old 07-08-2011, 05:22 PM   #7
Classic Heartbeat
Re: Grrrrrr
Wouldn't be a short anywhere. If it were a short it would arc out and either get the wires hot or burn them up.
Bad connections could be the problem, just take the wires all loose and clean up the connectors and reinstall. (I do mean all of them. Even the ones where it plugs into the fuse panel) It wouldn't hurt to do that anyway.
If the problem isn't solved then start looking into a new ignition switch or starter solenoid.
If when you turn the key, you get absolutely nothing, not even a click, then that would rule out the solenoid. If you get a loud click that means low battery, or poor starter alignment. A somewhat quieter click could mean stickey solenoid.
None of that however will not rule out the ignition switch or the nutral safety switch.
Try turning the key while wiggeling the shift lever a little back and fourth. If it starts it is a shift linkage adjustment problem. If the problem is on the electrical side of the nutral safety switch it either works or it doesn't.
You can check the ignition switch just by trying to turn the key repeatedly. If it sometimes works and not others then replace it.
None of these tests are set in stone nor do they garantee success. They are rule of thumb and a good starting point. Good luck, WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 07-08-2011, 05:34 PM   #8
bimaldo
Re: Grrrrrr
thanks for the advice, perhaps I was not clear in my original post.
never had a problem with the solenoid engaging or the starter turning the engine,
it would turn and turn and turn (long enough to drain the battery) it just never started.
I am no electrical whiz, but I was thinking is there some connection in the ignition switch that might be going south that would inhibit energizing the coil?
Old 07-08-2011, 06:02 PM   #9
Wrenchbender Ret
Re: Grrrrrr
I took it as a starter problem too. First remove the air cleaner & look down the carb. Each time you work the throttle a squirt of gas should go into the throat. If not try pouring a little gas in the carb & try it. If it starts then you have a fuel problem. If not remove the coil wire from the cap & with it close to the engine crank the engine. You should get a blue spark jumping about 1/2 in. If not the ign. system has a problem.
Wrenchbender Ret is offline   Reply With Quote
Old 07-08-2011, 06:47 PM   #10
Classic Heartbeat
Re: Grrrrrr
Those statements do conflict, however what you are talking about now could be electrical or carburetion. You need to pull a spark plug to see if you are getting spark. If so it should be carb related. Spray starting fluid into the carbureter and see if it starts. If not it could be the carb needs work or you have a bad fuel pump. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 07-29-2011, 07:30 PM   #11
bimaldo
Re: Grrrrrr
Alright, so now I feel stupid. Moisture in the distributor cap.
New cap and button and I'm back in business.
Thanks for your input. I can not imagine what I'd do with out this Community.
Old 07-29-2011, 08:01 PM   #12
stich626
Re: Grrrrrr
Originally Posted by bimaldo View Post
thanks guys,
bill
turns over just no fire?
I'd say the fuel is backing down the line and the carb fuel bowls are empty
stich626 is offline   Reply With Quote
Old 07-29-2011, 10:55 PM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Grrrrrr
what part of columbus are you in?
