04-03-2003, 08:49 PM | #1 |
front end torque specs
Hey everyone, I need some help with torque specs. I don't have a book with the front end torque specs I need and would like if a fellow member could help me out here. Here's what I need:
Upper ball joint spindle nut Upper ball joint mounting bolts Lower ball joint spindle nut Upper A-arm cross shaft to frame bolts Lower A-arm cross shaft u-bolts I'm getting ready to rebuild my front end and need these numbers. Thanks.
My engine is stock... trust me ;o) |
04-03-2003, 09:02 PM | #2 |
71 stepside asked me a while back the specks are on the board somewhere. I dont have them off hand anymore.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
04-03-2003, 09:13 PM | #3 |
low control arm ubolts45ft'lbs
upper control arms70ft'lbs upper ball joint nut50ft'lbs low balljoint nut90ft'lbs as far as the torque for the ball joint retainer bolts that should be in the instructions of the replacement part it's been awhile since i did ball joints but i think it was about 25ft'lbs all the other torque figures i gave you are for c10 from factory manual
04-03-2003, 11:45 PM | #4 |
Thanx bro..... that's exactly what I was looking for. Stupid me forgot to say my truck is a 1/2 ton
