Old 07-08-2011, 05:25 PM   #1
racosta16
racosta16's Avatar
1970 C10 driver window stuck
I was rolling down the window when the handle stopped and now won't roll either way. I tried removing the panel but cant get the pins off for the door handle and window. Once that is done, should it just be an easy fix? thoughts?
racosta16 is offline   Reply With Quote
Old 07-08-2011, 06:54 PM   #2
BMERDOC
BMERDOC's Avatar
Re: 1970 C10 driver window stuck
There was a thread just the other day on how to remove the handle clips. Use a rag to get behind the handle, use the cheap stamp steel tool or my personal favorite, a hook tool. Once you pull the clips off and remove the handle pop the clips back into the grooves so you don't lose them and simply slide the assembly back on when it all goes together.
As far as the binding look for anything conspicuous. If its just a frozen regulator douse it in PB Blaster or your favorite penetrant. Work it in by moving the window up and down and finish off with a heavier grease like syl glyde or a white grease spray.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 07-08-2011, 11:26 PM   #3
68 IRON
68 IRON's Avatar
Sounds like mine! If you can grab the window pull or push it while turning the handle. Loose or worn track will do this.
68 IRON is offline   Reply With Quote
Old 07-08-2011, 11:29 PM   #4
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i bet the regulator arm pop off the track like mine i took mine out and recondition them and grease them up and replace the felt while i was in there ,im going to redo them again later with electric door and windows with one pc. window kit ,
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
