fan not centered??
im in the process of either puttin electric fans or shroudin and extending my mechanical...one thing i just noticed though, my fan now is no where near centered in the radiator. it sits in the bottom of the radiator, the top of the fan blade is in the center of the radiator..so almost 1/4 to 1/2 of my radiator is ot being cooled..my motor looks like its sitting too low looking at other pictures of engine bays..why would this be...wrong motor mounts?? it looks as if the motor should be two to three inches up more.
Re: fan not centered??
What are you running ,,,,? I have s blk with stock shroud, they are positioned low in accordance to the radiator...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
![]() Join Date: Nov 2007
Clamp a board to the bottom of the cross member, sticking out under the crank pulley, and measure up to the center line of the crank. My original 283 sat 11" from the bottom of the cross member to center line of the crank.
TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
