Old 07-08-2011, 08:48 PM   #1
Beat68CST
Beat68CST's Avatar
Driprail replacement
How hard is it?
It's disappointing, my cab is completely solid, minus the tiny spots in the floor corners, the cab corners themselves are hard as rock, along with rockers and cab supports.
My driprails are damn near gone... Anyone have a thread on it?
Beat68CST is offline   Reply With Quote
Old 07-08-2011, 09:38 PM   #2
BMERDOC
BMERDOC's Avatar
Re: Driprail replacement
Do you plan on hot roddin' your truck or restoring it? If your gonna hot rod it peep this: http://www.customclassictrucks.com/t...rty/index.html
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 07-08-2011, 10:25 PM   #3
bcutt
bcutt's Avatar
Not hard at all, Just drill out the spot welds and weld the new ones back on. Although I don't know who makes replacements. I was able to sand blast mine and weld them back on.
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see."
- Thomas Jefferson
72 C10 SWB "Work in Progress"
bcutt is offline   Reply With Quote
Old 07-09-2011, 06:50 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I got a pair of repro's from Classic industries for $20 a piece. I haven't tried to install them yet so not sure what to expect.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 07-09-2011, 08:50 AM   #5
bigsnookmaster
bigsnookmaster's Avatar
I've done donor top replacements without much problems. Sometimes you don't know what there's going on behind the driprail!
bigsnookmaster is offline   Reply With Quote
Old 07-09-2011, 09:02 AM   #6
bcutt
bcutt's Avatar
That's good to know, I originally ordered a set fro ECE but they called me and told me they no longer sold them because they fit like crap. I almost resorted to making myself a set.
- Thomas Jefferson
Old 07-09-2011, 11:17 AM   #7
slikside
slikside's Avatar
subscribed. please let us know how this project works out for you. My driver's side waisted! Been rust'n out and falling apart for years.
slikside is offline   Reply With Quote
Old 07-09-2011, 12:18 PM   #8
ls1nova71
ls1nova71's Avatar
I agree, I'd replace the whole top. If your driprail is rusted, then the metal it attaches to is going to be rusted also, so you would be doing alot of patching. Replace the top and save some time and work.
ls1nova71 is offline   Reply With Quote
Old 07-09-2011, 01:38 PM   #9
Beat68CST
Beat68CST's Avatar
Anyone heard of stainless steel replacements, I think I found a set locally.
The top skin of my cab is fine, it's clearly just the driprail rusted away.
What do you guys use to get em sealed back up, caulking wise, something that will take some damage from the heat here in Az.
Old 07-10-2011, 07:41 PM   #10
bcutt
bcutt's Avatar
This is what I am using, it's 2-part self leveling, so its ultra tough and can be applied with a standard caulk gun.
http://autobodystore.net/Merchant2/m...gory_Code=JASS
Never heard of stainless drip rails and don't see the need for them (besides the problems you would have welding them to the cab). Apply some good weld through primer to your new drip rails and the surface of the cab and after welding apply some good Epoxy Primer this seam sealer above. Do it right and it will last another 40 years
- Thomas Jefferson
