Old 07-09-2011, 09:40 AM   #1
baclay9
No power to injectors on 90' 7.4L...HELP PLEASE!
Just picked up a 1990 1 ton with a TBI 454. It wasn't running when I got it. I changed the filter and fuel pump.
The engine will run like a champ if I spray starting fluid down the throttle body.
I am getting no power to the injectors on the throttle body. There is no constant power on the hot side and no intermittent ground on the signal side. The injectors will spray if i jump them with a wire so I know they are good. I am just getting no power to the wires.
Can someone please give me a clue on where to look for a problem I have checked the wiring out and it all looks good but I am not sure which connector under the dash goes to the Throttle body.
baclay9 is offline   Reply With Quote
Old 07-09-2011, 02:37 PM   #2
onequickchevy
onequickchevy's Avatar
Re: No power to injectors on 90' 7.4L...HELP PLEASE!
Module in distributor, it controls the pulse for the injectors. Very common problem.
Slowly but surely getting it done.
onequickchevy is offline   Reply With Quote
Old 07-09-2011, 04:04 PM   #3
baclay9
Would that explain why there is no power on the "hot" side as well? I was under the impression the module just controlled the negative side. I am new to all of this so thank you for your help.
Old 07-09-2011, 07:02 PM   #4
ChevyTech
Have you check for power at the injector fuse in the fuse box?
Old 07-09-2011, 07:03 PM   #5
ChevyTech
You are correct.
Old 07-09-2011, 07:19 PM   #6
baclay9
Yes, there is power at the injector fuse. I am just not sure where to go from there.
Old 07-09-2011, 07:23 PM   #7
ChevyTech
Is a 1990 1 ton still the old square body?
On the body style after the square body, the wires to the injectors go through a connector that is close to the ECM.
Old 07-09-2011, 07:50 PM   #8
baclay9
It is the newer body style. So do the wires from the injectors plug into the ECM at all or are they on a different connector?
Old 07-09-2011, 08:01 PM   #9
ChevyTech
The white & red injector wires splice together inside the harness to one red wire. One bad terminal in the connector will stop both injectors.
The red wire goes through a large connector (about 15 wires) in the area of the ECM and blower motor. This connector does not go to the ECM. It is close to the ECM. One side of the connector is one piece with two rows of terminals, and the other side is two seperate flat connectors that plug into it.
Old 07-09-2011, 08:12 PM   #10
onequickchevy
It may be possible to run a temporary jumper wire to isolate the problem. Chevytech is your best bet for an answer on that .
Old 07-09-2011, 08:34 PM   #11
baclay9
Ok, I see it. The red wire in it doesn't have power on either side of the connector.
Old 07-09-2011, 08:40 PM   #12
ChevyTech
Go to the fuse and test the terminals that connect to the fuse for power. Sometimes the terminal gets burnt that the fuse plugs into.
If you did not find the fuse terminal to be bad I would test the wire a couple inches away from the fuse.
Old 07-09-2011, 08:54 PM   #13
baclay9
Which fuse terminal should I be checking? Is it the one labeled (INJ A+B)?
Old 07-09-2011, 08:59 PM   #14
ChevyTech
Yes; Inj A&B
Check all the fuses around it because sometimes the label by the fuses are hard to tell if they go to the fuse above it, or below it.
The schematic I am looking at shows the red wire in cavity “E” of the connector by the blower motor. The letters on the connectors are small and sometime hard to find.
The red wire from cavity “E” (which is circuit 481) goes all the way to the injector fuse.
Old 07-09-2011, 09:09 PM   #15
baclay9
Ok I fiddled around with the fuse terminal and now I have power all the way out to the tbi plug. The battery is too low to crank the motor over right now so I put it on the charger. I will check back in after while and let you know what it does. Thank you so much for getting me this far.
Old 07-09-2011, 09:29 PM   #16
baclay9
It just started right up. Thank you so much for your help! I never would have been able to figure that out on my own.
Old 07-09-2011, 09:41 PM   #17
scotts62
One day...
scotts62's Avatar
Cool so it was a simpler fix than we thought huh? Glad you found it!
Chevytech is the hero again
Scott
93 crew cab build
Project 62
Old 07-09-2011, 10:05 PM   #18
onequickchevy
Excellent news!
Old 07-09-2011, 10:20 PM   #19
ChevyTech
You’re welcome!
Glad to hear you got it running.
Clean the fuse terminal real well so it does not give you more trouble.
You may need to bend the terminal to pinch the fuse tighter.
Old 07-09-2011, 10:25 PM   #20
ChevyTech
Thanks!
ah
um
Does that mean I can take a break from the board again?
Old 07-10-2011, 03:07 PM   #21
scotts62
One day...
scotts62's Avatar
Originally Posted by ChevyTech View Post
Thanks!
ah
um
yeah you can have a couple days off
Scott
93 crew cab build
Project 62
