Old 07-09-2011, 01:44 PM   #1
chuckthetruck
chuckthetruck's Avatar
Alternator install help
The water pump is in thank you very much! The alternator was bad so I have a new one I put in however....as it is my first time installing one I have an extra hot wire coming directly from battery that I did not re install( stupid newbie mistake) and cannot figure out where it bolts on. Help?
chuckthetruck is offline   Reply With Quote
Old 07-09-2011, 02:27 PM   #2
J Knight
J Knight's Avatar
Re: Alternator install help
The wire you speak of, is it the negative battery cable?
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 07-09-2011, 02:34 PM   #3
chuckthetruck
Nope looks like it is coming from positive side
Old 07-09-2011, 03:05 PM   #4
J Knight
J Knight's Avatar
Can you post a pic?
John
Old 07-10-2011, 01:32 AM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
What do you mean by extra? Do you already have the one power hooked to the starter and the one to the back of the alternator?
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 07-11-2011, 08:40 PM   #6
chuckthetruck
Here is the picture of what I have left. I have the 2 prongs plugged in and the wire under the nut. This is what is left...I am a newbie at this but I do not remember undoing this wire...but I must have...
Old 07-11-2011, 08:58 PM   #7
J Knight
J Knight's Avatar
So thats the wire that goes to the positive battery post? Is it built into the positive battery cable? Got a pic of the other end of that wire?
John
Old 07-12-2011, 10:04 AM   #8
chuckthetruck
hope this helps....it is EXTREMELY sunny and hot outside so the camera kept fogging over!
Old 07-12-2011, 10:24 AM   #9
Telecasterjoey
looks to me like its the ground that goes to the frame.
Telecasterjoey is offline   Reply With Quote
Old 07-12-2011, 10:35 AM   #10
chuckthetruck
well if it helps...when i "accidentally found it" and grounded it out...sparks flew and the motor about died out.
Old 07-12-2011, 11:12 AM   #11
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Isn't that your charging wire? If it is, it goes on the little stud with a nut on the back of your alternator.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 07-12-2011, 11:28 AM   #12
chuckthetruck
well I already attached the wire that came off there...thin red wire to be exact.
Old 07-12-2011, 01:07 PM   #13
J Knight
J Knight's Avatar
If your alternate is working and charging your battery with no issues, tape it off and zip tie it secure and you should be fine. My bat cables don't even have that wire.
John
Old 07-12-2011, 01:17 PM   #14
kelsfine69
18 Till I Die
kelsfine69's Avatar
That is the charge wire for the back of the Altenator. It is a must! I would hook it up and find out where the other wire leads off to. Might be a Previous owner hook up for something else.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 07-12-2011, 01:51 PM   #15
chuckthetruck
On the post under the nut?
Old 07-12-2011, 01:52 PM   #16
lindstromjd
Where does the wire that you already hooked up go to? I'm guessing either to the starter or to the fuse block. Either way, you should just hook up both wires under the stud/nut on the alternator.
-357 / 700r4
-350 / TH350
Old 07-12-2011, 02:38 PM   #17
kelsfine69
18 Till I Die
kelsfine69's Avatar
Yes. I guessin someone ran another wire to the stud for a power sorce for something? Disconnect it and see what doesnt work?
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 07-13-2011, 07:17 PM   #18
chuckthetruck
it worked and we are back running again with new alternator and water pump. Thank you..we are reading out right above 13 on the battery meter and not getting over half way on heat....GREAT NEWS!!
Old 07-14-2011, 01:05 AM   #19
Hoods69BadBowTie
Chevys Kick A$$
Nice that's good to hear glad you finally got it fixed. Now got drive the truck and get out and enjoy it.
-LATER
