Old 04-03-2003, 10:12 PM   #1
blood
chat down again #%$#
the chat server is down but for now you can all connect to this server till the other one is fixed any way heres the info if you need help im me yodycass or post a message i still need to talk to who ever is in charge of the chat
MIRC open it up, then under MIRC options in the top right corner there will be a "ADD" button, click on that, then under description put anything you want, I use "67-72trucks"
Under IRC server put: irc.ugc.net
Under port(s) put: 6667
And put nothing under group also nothing under password. Then click "add" after that is done go back to the main option page and fill out all the info. Real name, email address user name, etc. After that is done click "connect to IRC server", its in the middle. When you are connected to irc.ugc.net type: /join #67-72Chevy. THAN YOUR DONE! Now experience chatting on its full potential with mIRC! (took this from mirc instruction on site)
As the curtain calls, and the cast recedes, I am all that ever was and all that ever will be. In wither and repose this frayed chapter now does close, and fade into neon black
blood is offline   Reply With Quote
Old 04-03-2003, 10:13 PM   #2
Alexis
Member since 2000
Alexis's Avatar
i'm in chat right now.......it took days to load up
Alexis is offline   Reply With Quote
Old 04-03-2003, 10:19 PM   #3
blood
hmmmm
well i still cant get on and ive had it trying to connect for half an hour
Old 04-03-2003, 10:21 PM   #4
Alexis
Member since 2000
Alexis's Avatar
hmmmmm i use java
Old 04-03-2003, 11:12 PM   #5
Slams_58
the linkline server works
Slams_58 is offline   Reply With Quote
