Old 07-09-2011, 03:11 PM   #1
1972RedNeck
1972RedNeck's Avatar
My Valve Expanded.
Where can I get a new Made in USA expansion valve for my '72. I would rather drive in 120* weather with my windows down than to install a chinese/mexican one.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 07-09-2011, 08:38 PM   #2
clinebarger
Re: My Valve Expanded.
I would move away from the THX expansion/POA valve system. Are you still running the POA valve, Or one of those "cheap POA delete kits"? POA valves DO NOT work well with 134a.
The problem with THX valves is the system has to be perfectly clean, The smallest peice of debris can hang it open. THX valves are used on all kinds of eqipment all over the world...I doubt a "foreign" made one would cause more problems than a "USA" made one. Your worn/rebuilt A6 compressor is most likely throwing trash into the THX valve.
Changing it over to a "Fixed Orifice system" is pretty easy....A 77 Olds 98 evaporator & orifice tube will fit your evaporator case, Use a accumulator for a 77 chevy truck. Get rid of the receiver dryer off the core support. You will need some custom hose work done....The "liquid line" from the condenser to the evaporator will be custom, & the Suction line from the accumulator to the compressor will be custom. Just "rehose" the "discharge" line from the compressor to condenser.
clinebarger is offline   Reply With Quote
Old 07-11-2011, 12:21 AM   #3
69heavychevy
69heavychevy's Avatar
I hope you enjoy that 120 degree heat...
69heavychevy is offline   Reply With Quote
Old 07-28-2012, 11:43 PM   #4
72 K20
72 K20's Avatar
I'll be watching this !!
I'm going to change my '72 over to a serpentine setup with the newer style compressor.
I plan on keeping it R12. Any tips or pointers are greatly appreciated !!
Tom
72 K20 is offline   Reply With Quote
Old 07-29-2012, 12:10 PM   #5
tkeduk8r
tkeduk8r's Avatar
subscribed!
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 07-29-2012, 05:38 PM   #6
1972RedNeck
Since this was resurrected, I actually fixed my original expansion valve.
The process went like this:
1.Turn A/C on
2.Open hood
3.Tap on expansion valve with Leatherman
4.Enjoy cool air
5.Repeat steps 1 through 4 every time you drive for 10 or 12 times. Worked like a charm.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 07-29-2012, 05:47 PM   #7
1972RedNeck
I was going to have my valve sent in to be rebuilt before it started working.
http://www.classicautoair.com/GM_OEM_Parts_Valves.html
1966 F250 4X4 416
1972 K20 350 4 OTF
