Old 07-09-2011, 05:55 PM   #1
65Guy
Tilt Column pics!
I just got an 88 truck column. anyone ever us a newer truck column. Post up some pics!
65Guy is offline   Reply With Quote
Old 07-09-2011, 10:15 PM   #2
65Guy
Re: Tilt Column pics Please?
Come on guys. Im putting the 88 column in my 65 does any one have some pics of new columns in our trucks?
Old 07-10-2011, 12:11 AM   #3
Woogeroo
Re: Tilt Column pics!
Uhm... I've seen a few pics here and there... they never look right to me.
As for no replies, you posted on a Friday night... you may get some replies next week.
-W
Woogeroo is offline   Reply With Quote
Old 07-10-2011, 09:11 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I have put the 73 thru 87 tilts in and the 71-72 tilts in but not the 88 up tilts
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-10-2011, 11:03 AM   #5
Turkey
Turkey's Avatar
I did it in high school but that was in '87...if two high school kids can do it, it can't be that hard.
Turkey is offline   Reply With Quote
Old 07-10-2011, 11:25 AM   #6
kieth
kieth's Avatar
Heres one in my 66 gmc build, it is from a 91 suburban, I figured if I did not like it after I finished the truck I would just put a custom wheel in it. I used the 91 burb for , 350 tbi engine, trans 700r4, tilt, disc brakes, front crossmember, power steering , power brakes, cruise control, wiring, etc. only paid $600.00 for it. Kieth
http://kieth.smugmug.com/Trucks/66-G...738832_FCsG9GR
http://kieth.smugmug.com/Trucks/66-G...738746_6RPBQ7f
kieth is offline   Reply With Quote
Old 07-11-2011, 01:45 AM   #7
edflores
Bump. it shouldnt be that different from a 73-87 should it?
I want to do the same. The key tilt and shifter will work great in my truck
edflores is offline   Reply With Quote
Old 07-11-2011, 10:29 AM   #8
Clyde65
Clyde65's Avatar
If it is from the 88 newer trucks it might be totally different, 65Guy is it or is it from a square body?
Clyde65
Rebuild of Clyde
support our troops!
Old 07-11-2011, 12:56 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Aftermarket tilt in my 66
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-11-2011, 02:37 PM   #10
Clyde65
Clyde65's Avatar
Show off!
Clyde65
Rebuild of Clyde
support our troops!
Old 07-11-2011, 02:48 PM   #11
kieth
kieth's Avatar
pick up trucks from 88 on were different but suburbans did not change until 1992.........Kieth
Old 07-11-2011, 03:13 PM   #12
kieth
kieth's Avatar
The suburbans are the same up thru 1991 so the install will be the same,
here is a link where we show what had to be done to install the newer column in the 66 gmc. go through the gallery one picture at a time and it should be pretty self explanatory. If you would like to talk to me about it call me at the office 918-446-2245 Kieth
first step was merging the old and the new bracket
http://kieth.smugmug.com/Trucks/66-G...49353720_dNwFi
Next install the steering wheel with the merged bracket, we had to make sure it cleared the wiring from the 91 burb.
come to think of it I did not write this up very well, and it was not easy to do, we were just being cheap, Here is how this was done.
1. We used the wiring harness from a 1991 suburban, we also used the fuse panel from the same vehicle----In this way we did not have to worry about all the connections since we had all the stock 91 plugins.......
2. Then we welded and modified the 2 steering brackets from the 66 gmc and the 91 burb.
3. This allowed us to retain the brake pedal, brake light bracketry and the emergency brake lever from the 66 bmc......(blend the old with the new)
4. You will have to modify the firewall as shown to allow the neutral safety switch to clear the firewall (due to length)
5. You will have to shorten the steering shaft 1.5" approximately. This is a energy absorbing steering column so we drilled out the plastic in 2 holes , shortened the steering column and replaced the plastic with nylon bolts and nuts........
This is not for the faint hearted, a idit column would probably be cheaper....
Kieth
ps but being cheap we used it and it came out pretty good .....
Old 07-11-2011, 09:36 PM   #13
65Guy
it is not from a square body it is the next year model and the gear selector is in a different spot.
Old 07-13-2011, 06:17 PM   #14
kieth
kieth's Avatar
You are correct, a 1988 pickup column is not the same as my 91 burb, but the wheel does work in my 66 gmc, I am having to come up with a shift indicator but will cross that bridge a little later. Kieth
Old 07-13-2011, 07:33 PM   #15
samuellg1977
samuellg1977's Avatar
I put a 84 tilt column in my 63. It works, but i can't figure out the wiring for the horn, headlight dimmer, and i only get one speed on my wipers (go figure). It steers great and in all other aspects it is fine. I took the shifter handle off to run a floor shifter (cause i boogered up the column linkages) and I also had to bust up the ignition switch to unlock the column (cause i don't have the keys). Looks pretty ugly right now, but it works. Eventually, i will grind off and weld up the shifter and ignition openings and smooth it out. Til then, i'm gonna drive it like i stoled it!!
samuellg1977 is offline   Reply With Quote
Old 07-14-2011, 09:44 AM   #16
kieth
kieth's Avatar
Samuel, that looks like the same column as my 91 burban column. As I stated suburbans are the same body as a 87 pickup the pickup changed in 1988. One small difference the bell at the base is different, mine was attached to the upper housing and moved. I had to modify it to remain in place while the top rotated when shifting.
Old 07-14-2011, 10:52 AM   #17
Chevy Fleetside
Chevy Fleetside's Avatar
I tried to put an 88 column in my 65 but gave up when it wasn't working for me. I will just stick to the van columns. Anything up to 1980 will work. I found one at pick n pull for $28 when they were having a 25% off sale.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-15-2011, 11:03 AM   #18
bubba327
HOW long until spring??
bubba327's Avatar
A 77 nova column . I removed all the locking mechanism , ground off the key and made a aluminum plug to close off the remaining key opening and epoxied and roll-pinned in place.
Spent a LOT of time fabricating to re-use the emergency brake lever but it works great ..
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
