07-09-2011, 10:18 PM | #1 |
I deleted my voltage regulator, but I have 2 questions
I followed this FAQ:http://67-72chevytrucks.com/vboard/s...d.php?t=119379
Now I am left with 2 questions. I have a black wire in the bundle going to the alt, but nowhere to hook it to. Does it just go anywhere, like one of the little bolts that hold the alt. together? http://s3.photobucket.com/albums/y55...ernator010.jpg And at the regulator, I have a big red wire that still is on the connector to the regulator. What do I need to do with this wire? Any help would be great. Thanks, Pritch
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
07-09-2011, 10:20 PM | #2 |
Its a Truck Thing......
Re: I deleted my voltage regulator, but I have 2 questions
What alt did you get?
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
07-09-2011, 10:32 PM | #3 |
Msgt USAF Ret
The black wire is a ground between the external voltage regulator and the original alternator. The new alternator is grounded through the case so it no longer needs the ground wire.
The red wire in the plug is the voltage sensing wire for the regulator. It could have gone to the terminal on the alternator where you put the little jumper off the back of the new alternator as per the instruction in the FAQ. That would have given you a better read on the remote voltage sensing instead of taking it right off the back of the alternator. The other end of the red wire you mention is connected to the three-way connector in the harness and is hot at all times so you could run it to a fused junction as a lot of the fellows do to feed various things like headlight relays or cooling fans.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
07-09-2011, 10:56 PM | #4 |
Vette Vet, lemme get this straight-wire # 12R (in the diagram you post) @ the regulator should go to terminal #2 on the alt.? Or left as an aux. source of 12v power?
Thanks, Pritch
07-09-2011, 11:53 PM | #5 |
Msgt USAF Ret
Yes and here is the diagram.
12b is the black ground wire
07-10-2011, 01:20 AM | #6 |
I see. Thanks, Vet. I'll clean up these loose ends tomorrow.
07-10-2011, 09:33 AM | #7 |
"brand new second-hand"
Pritch-what/where did you get he alternator from-I want to do the swap too but not sure which is a good year to get.
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
07-10-2011, 12:46 PM | #8 | |
I'll watch those wires to see if they get hot at all. Last thing I want is to have a melt down.
07-10-2011, 09:31 AM | #9 |
Pritch,
All the red wires are connected together at a lug down in the corner of the driver fender, according to what alt you put in if you dont upgrade the wire size it can run very hot over at the battery connection, (Mine did) I replaced all the red wire with 10 g wire (except the one going back to the fuse block) and mine is charging better and not getting hot (So far). Keep an eye on it, grab the wire that is going to the battery from the lug and see its condition. You will know if your going to be ok or not. Smitty
07-10-2011, 11:02 AM | #10 |
Msgt USAF Ret
This is my mess where the wires are joined.
Most any GM alternator in the 80s will work but get one for a larger vehicle like cadillac or buick. If you look at the diagram I posted in my first post it shows a small black/white wire with a fuse that also goes to this junction. This is the alternator side of the battery gauge in the dash. Idiot light trucks did not have this wire so for those of you that have the battery gauge (ammeter) you should have this wire and the other side of the gauge goes to the terminal bolt on the right passenger fender.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 07-10-2011 at 11:07 AM. |
07-10-2011, 02:48 PM | #11 |
With the SI you may be ok, the CS and above put out alot more amps which my wires couldnt hold.
Smitty
07-10-2011, 11:39 PM | #12 |
I went for a 40 mile quick trip to Home Depot today and the wires didn't get hot at all. I'll keep my eye on things, though. Thanks, everyone
07-11-2011, 08:28 AM | #13 |
No problem,
Remember VetteVet "Is the Man" when you need electrical help....I just go out there and burn stuff up.... Smitty
