Old 07-09-2011, 11:36 PM   #1
71Custom10
71Custom10's Avatar
rotors and calipers
Are there different rotor thicknesses in '71 and '72 and different calipers to fit them. Just replaced my pads and calipers and they wont go over the rotors unless i hammer them on, then the rotor will not turn because the outside pad is tight against the rotor, but there is space between inside pad and the rotor. Help
'67 Chevy Longbed Fleetside - Daily Driver(For Now)
'72 Cheyene Longbed Fleetside-Daily Driver
Best Towing Service
71Custom10 is offline   Reply With Quote
Old 07-10-2011, 12:21 AM   #2
beautimus
beautimus's Avatar
Re: rotors and calipers
Your caliper is not floating on the mounting bolts like it is supposed to.
the caliper has to be able to slide left to right on the mounting bolts in order for it to center itself on the rotor. remove the caliper, and take the pads out. then put the caliper back in place and install the bolts. you should be able to slide it freely back and forth. add a couple of drops of light weight oil to the shaft of the bolts if it doesn't slide like its supposed to. DON'T put a lot of oil, wipe of any excess before you put the pads back in, and you shoould be fine.
Tony
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 07-10-2011, 05:11 PM   #3
71Custom10
71Custom10's Avatar
anyone else
Best Towing Service
Old 07-10-2011, 05:57 PM   #4
Classic Bowties
Always on the hunt...
Did you match up/compare your original calipers with your new one's before swapping them out, its possible that you got later calipers designed to work with the later style 1" rotors? Your 71 should have 1-1/4" rotors. Mel
Classic Bowties is offline   Reply With Quote
Old 07-10-2011, 07:58 PM   #5
71Custom10
71Custom10's Avatar
no i didnt match them up first. But i did go to a different store and get another set and same problem. Its actually on my '72, and they are 1 1/4 rotors. Anybody got a set laying around that they can measure the inside width for me.
Best Towing Service
Old 07-10-2011, 08:56 PM   #6
swierker
swierker's Avatar
I do happen to have a caliper laying around. It's hard to see in the pics but the 1st is 2.5" and the second is 3". Hope this helps.
1970 Chevy LWB - 305/350
In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's.
swierker is offline   Reply With Quote
Old 07-10-2011, 08:58 PM   #7
truckster
truckster's Avatar
No intention to offend, but are you sure the pistons are all the way back into the calipers?
truckster is offline   Reply With Quote
Old 07-10-2011, 09:22 PM   #8
beautimus
beautimus's Avatar
[QUOTE= the outside pad is tight against the rotor, but there is space between inside pad and the rotor. Help[/QUOTE]
This tells you that the caliper is not centered on the rotor. the only way that can happen is if your caliper is not free. I have found this more times than i can count. When you took the old pads out , one was worn a lot more than the other am i right? Remember they are called FLOATING CALIPERS....
ok now i'll shut up....... best of luck to you, Tony
Old 07-10-2011, 09:35 PM   #9
71Custom10
71Custom10's Avatar
the piston is all the way in. the inside pad is not even touching the rotor. they are free floating with out the pads in but that allows them to pull towards the rotor, which is the problem. the distance from caliper mounting surface to outside pad surface seems to be to little. the two sets i bought are 2.5". what are the 3" one off of?
Best Towing Service
Old 07-10-2011, 09:36 PM   #10
71swb4x4
71swb4x4's Avatar
Like the others said, your caliper is not floating. Free it up and your problem should go away.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-10-2011, 09:36 PM   #11
71Custom10
71Custom10's Avatar
different measuring points, duh. thought we had a solution
Best Towing Service
Old 07-10-2011, 11:07 PM   #12
70cst
70cst's Avatar
Good learning thread ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 07-10-2011, 11:23 PM   #13
7T2
Active Member
7T2's Avatar
A picture might help, if you can post one. Sometimes in frustration you can miss something obvious.
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 07-11-2011, 11:20 PM   #14
71Custom10
71Custom10's Avatar
what am i missing
Best Towing Service
Old 07-11-2011, 11:33 PM   #15
Classic Bowties
Those spindles pictured are not 72's, and I would say that is what is giving you the problems. Mel
Old 07-11-2011, 11:45 PM   #16
71Custom10
71Custom10's Avatar
those are cpp's modular drop spindles with brackets for stock calipers. They've been on there for a couple of years.
Best Towing Service
Old 07-11-2011, 11:50 PM   #17
Classic Bowties
Here is picture of a 72 C/10 spindle, again I am sure this is where your problem lies. Mel
Old 07-11-2011, 11:57 PM   #18
ls1nova71
ls1nova71's Avatar
Looks like your caliper is hitting the caliper bracket, and not letting it slide outward enough.
ls1nova71 is offline   Reply With Quote
