Old 07-10-2011, 12:32 PM   #1
pat321
Cool 2006 Stance
Hey guys I just bought a 2006 Chevy 2 wheel drive pick up; its a crew cab with the 5.3 ltr. engine and only 28000 miles. It is a great truck and my wife and I both really like it but it sits a little to low (245/70/17). what is the best way to get it up a little without killing the ride?
pat321 is offline   Reply With Quote
Old 07-10-2011, 12:36 PM   #2
Sillyoldman
#16876
Sillyoldman's Avatar
Re: 2006 Stance
I don't have an answer for you on that. I'll move this to "suspension" for you. Welcome to the board.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 07-10-2011, 12:42 PM   #3
pat321
Re: 2006 Stance
Thanks!
Old 07-10-2011, 01:56 PM   #4
6772owner
Gearhead
6772owner's Avatar
Re: 2006 Stance
On the 06' you can purchase a front end levelling kit that consists of new torsion bar keys and longer front shocks (2" +/-), you can also use a lift block in the rear if you want to retain the factory rake at the lifted height. The other option is a complete susension lift kit (available in 4", 6" and up) or a body lift kit (usually 2" or 3") I personally dont care for the looks of the body lift on these trucks. You see a lot more of the frame and if it has a hitch this creates a gap between the hitch/bumper or bumper and bed. Just my .02
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 07-10-2011, 06:31 PM   #5
pat321
Re: 2006 Stance
Can I run a larger tire with the modest lift that you refere to?
Old 07-10-2011, 06:57 PM   #6
6772owner
Gearhead
6772owner's Avatar
Re: 2006 Stance
Yes, you should be able to run a 285 or 295 (roughly a 32") on the factory wheels, you would have to careful with back space/offset on aftermarket wheels (may have to trim the front air dam)
Old 07-11-2011, 01:57 PM   #7
Shane
Shane's Avatar
Re: 2006 Stance
2wd has torsion bars?
Shane is offline   Reply With Quote
Old 07-11-2011, 02:04 PM   #8
6772owner
Gearhead
6772owner's Avatar
Re: 2006 Stance
WOW Shane, I didnt even notice the 2wd, I was thinking 4wd in my head, I guess I didnt read that correctly on my phone before I posted. I still think that Fabtech should have some lift components for the 2wd. I would bet there are also spacers/leveling kits for the 2wd's anyway.
Great catch Shane and I apologize to the OP for this!!
EDIT: It appears that 04-06' could have torsion bar or coil, so pat321, you will have to check and see what the truck has. Fabtech does offer lifts for both versions of the truck though.
They have a 3" spindle lift for the coil trucks and Im sure someone has levelling keys for the torsion bar trucks.
Here's the link for the Fabtech stuff.
http://www.fabtechmotorsports.com/pr...uct_list&c=343
Old 07-11-2011, 09:16 PM   #9
55belairtim
Re: 2006 Stance
there are 2wds with torsion bars ext cabs with 5.5 ft beds have them as well as the vho's (ss 2wd)
looks like coil spacers for you since its most likely got coils in it.
55belairtim is offline   Reply With Quote
Old 07-11-2011, 09:27 PM   #10
6772owner
Gearhead
6772owner's Avatar
Re: 2006 Stance
I would rather see the use of the lift spindles if it is a coil spring truck, then there is no shock or geometry change. Just my opinion, thanks for the info as well! I didn't realize some 2wds had torsion bars too (well I knew Avalanches and HD trucks did, not 1/2 tons)
Old 07-11-2011, 09:38 PM   #11
71swb4x4
71swb4x4's Avatar
Re: 2006 Stance
His sounds like a 1/2 ton and he did say CC, so it would have the 5.5' bed. I didn't know that extended cabs came with the 5.5' bed, is that true?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
