sway bar
I have a 58 swb 2 wheel drive on a stock frame stock front suspension
v -8 What is a good sway bar to use or would one help It is a driver just want it to handle well Gene Sharp |
Re: sway bar
Welder series. You can fab you own up. I'm using one of these on the rear of my '59. Up front I have a '79 Camaro sub frame and I am using the factory sway bar. I may step up to an after market one soon.
http://www.welderseries.com/blog/onl...way-bar-parts/
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
Re: sway bar
you mean an anti-sway bar that limits side-to-side movement of the frame/truck over the axle? Or an anti-roll bar that limits the amount of body tilt or lean in corners? These are very different things, sway bar usually on the back, anti-roll bar on the front. usually.
curious, stock trucks usually don't have problems in either of these areas. What kind of shape are you spring mounts and shackles in? |
Re: sway bar
Have always called both "sway bars"
I mean the front one just thinking of making it handle little better while I am rebuilding it all will get newbushings etc after all is getting lots more power Gene Sharp |
