Old 07-10-2011, 05:55 PM   #1
83highsierra
83highsierra's Avatar
axle flip question
ok so im gonna do an axle flip on my 83 stepside other than the obvious perches do i need to replace or modify anything and how bad will it look til i get the front done? and should i just cut the springs in front?
83highsierra is offline   Reply With Quote
Old 07-10-2011, 08:15 PM   #2
SCOTI
SCOTI's Avatar
Re: axle flip question
Flip kits come w/flip brackets, u-bolts w/hardware, & shock relocators.
The flip brackets not only position the axle above the spring-pack, it physically positions/relocates the housing to compensate for the drop (helps center the wheels in the wheel well).
It's recommended to replace the u-bolts when servicing/swapping.
The shock relocators are needed to get better travel geometry for the shocks.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-10-2011, 09:02 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
....and should i just cut the springs in front?
There is nothing wrong with cutting stock springs as long as you don't get them too hot. One coil will get you +/- 2" so you will still need more up front if you plan to set fairly level.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-11-2011, 10:09 PM   #4
papsoldblue72
papsoldblue72's Avatar
ok i am wanting to lower my 72 it has leaf springs can i do the same or do i need to do something else ?????
papsoldblue72 is offline   Reply With Quote
Old 07-11-2011, 11:00 PM   #5
SCOTI
SCOTI's Avatar
You just need a flip kit for the earlier 67-72 2.25" width leafs. Check the DJM line of products from one of our supporting vendors.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
