Old 07-10-2011, 06:57 PM   #1
bruin_d
bruin_d's Avatar
Questions for the Porterbuilt dropmembered guys
I did a test run on putting the motor in. In order for there to be room between the pan and rack and pinion I needed to tilt the motor back. This is how far it needed to go back to fit a piece of paper between the pan and rack. Does this look normal to you guys? Ivee been trying to find some pictures of motor shots but there doesn't seem to bee much.
bruin_d is offline   Reply With Quote
Old 07-10-2011, 07:02 PM   #2
bruin_d
bruin_d's Avatar
Re: Questions for the Porterbuilt dropmembered guys
Pictures wouldn't load the first time.
Old 07-10-2011, 07:34 PM   #3
bruin_d
bruin_d's Avatar
One more picture...
Old 07-11-2011, 12:33 PM   #4
colin_havens
colin_havens's Avatar
Something is definately not right there. Although Im not running a dropmembr but rather a Suicide Doors raised crossmember, the basic setup is pretty much the same. My motor is still at the same basic level it was stock, but raised just a little. Nate has always been VERY supportive to any of his customers, even to me when I had some questions and was running a different crossmember. Im sure he will chime in here and have some answers for you.
colin_havens is offline   Reply With Quote
Old 07-11-2011, 02:17 PM   #5
Jparks
Jparks's Avatar
Did you check the angle on the transmission tailshaft? Mine looks similar to that but I don't have the body on to know if it's that tilted. It does move the motor up 1.5" and forward about 1.5" so this could be correct.
Jparks is offline   Reply With Quote
Old 07-11-2011, 02:58 PM   #6
bruin_d
bruin_d's Avatar
After emailing back and forth with Nate he thinks I have a SBC drop member. He has a jig made up to make different motor mounts (probably has happened before). He's going to make some new mounts.
As for the angle, I don't have the tranny on yet. If i measure off of the head it is just shy of 9 degrees. Nate says it should be around 5-6 degrees.
