07-10-2011, 10:15 PM | #1 |
Edelbrock 1406 Problems
I took my truck to the mountains this weekend. It performed perfectly on Friday. On Saturday, I fired her up, and she ran like crap. When I turned off the engine (actually, it died), fuel was leaking out of the driver side of the carburetor, and I could see fuel dripping from the driver side front jet. I took off the top of the carb (after having a friend bring me a torx tool), checked out the floats and put it back together. She ran like a champ for about 100 miles with stop and go traffic. However, as soon as I got off the freeway, she loaded up and died. I managed to get it restarted, and it ran decently the rest of the way home.
Any ideas as to what may be going on?? Sticking float? Do I need to rebuild the carb??
1972 Chevy C-10 ~ 188,000 miles give or take |
07-10-2011, 10:44 PM | #2 |
Re: Edelbrock 1406 Problems
I don't have an answer but here is a bump for you...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
07-10-2011, 10:53 PM | #3 |
Kid's Mechanic
Might need to replace the fuel filter , have seen some come apart and send gunk thru . Sounds like a piece something stuck the needle open and then washed it thru
07-10-2011, 11:29 PM | #4 |
sounds similar to my problem, run great for one trip.. then 2hr. later .. run like crap.. i dont get it .. but i love it. Take a look at some past threads.. i know there is a tuneup manual pdf file floating around for the 1406.. i have one as well.. good luck
nate
72' Chevy C-10 Custom Deluxe 350 bored over .30 Th350 Tranny 3.73 gears flowmaster 40 series 87' Ford Mustang GT 302 HO Underdrive pulleys, 3.73 gear, flowmasters |
07-10-2011, 11:35 PM | #5 |
maybe due to the change in elevation...
07-10-2011, 11:39 PM | #6 |
Grandpa in the rustmobile...
I know edelbrocks with out the 'edelbrock pump' or a regulator flood and make nasty stains on the manifold (mine does )
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
07-11-2011, 01:37 AM | #7 |
Well, I just installed a fuel pressure gauge and changed the fuel filter. Maybe that will help. The pressure fluctuates back and forth between 5 and 7 psi pretty rapidly.
07-11-2011, 09:50 AM | #8 |
Take a look at Posts #16-18 in my Project thread and see if that is any help. Edelbrocks need pressure regulation.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
07-11-2011, 01:40 PM | #9 |
I don't have a pressure regulator on my '71, but that's next. The PO had changed all the jets and rods to run very rich. I'm at 5,400' and drive a lot over 9,000'. Get the Edelbrock manual for the 1406, Do you have all the stuff for #1 factory settings. If you don't know, take the top off and check the jets and rods. I'm changing mine to setting #10 (on the graph). My friend has a '72 and he put a PR on his, but he is changing the jets to run leaner on both barrels. Also, how much heat do you have on the fuel line? I have a ton!!! so I'm going to wrap the SS line with black rubber fuel line and then in thermal wrap to isolate the heat.
07-11-2011, 01:55 PM | #10 |
If fuel pressure is the problem. Would that present as a problem that comes and goes??
07-12-2011, 01:29 AM | #11 |
OK. Yesterday, I changed the fuel filter, and now my fuel pressure gauge moves so fast I can barely even see the needle. It fluctuates like mad between 0 and 10 psi. That can't be right, can it? The needle is a blur!
07-12-2011, 02:20 AM | #12 |
1969 Short, Fleet, and Beat
10 psi is way too much. That will definitely flood the carb.
This of course if your gauge is reading accurately. First things first, what fuel pump you using? |
07-12-2011, 02:22 AM | #13 |
An OEM fuel pump. Thinking about possibly purchasing the Edelbrock 1721.
07-12-2011, 02:53 AM | #14 |
I had this type of thing happen to me after a tune-up a couple of years ago. All of a sudden I was soaking the plugs and it ran like crap with gas everywhere. I took the air horn off (the top of the carb) and poked around looking for answers. I found a lot of residue in the float bowls, and so I cleaned out the needles and seats and reinstalled the top of the air horn. NO problems after that.
I don't know how long you've had yours, or what type of filter setup you have, but I run two filters because of that. I think getting heavy contaminates in your carburetor - possibly from your gas tank can clog things up in a hurry, and the carb will just flood itself.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
07-12-2011, 11:08 AM | #15 |
I looked and edelbrock gets around $100 for their pumps?!?!!?!?!?
Seemed kinda high.. What regualtor setup are you guys usiing?
07-12-2011, 02:14 PM | #16 |
*** That's interesting ***
When I use Edelbrock carbs, I always be sure to use their pump too. It doesn't need a regulator nor does it need dialed in. It just works.
Be sure to put the filter AFTER the pump and have a sock on the pickup in the tank.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
07-12-2011, 02:17 PM | #17 |
Good deal. Is installing an Edlebrock pump a simple changeout? In other words, unhook the hoses, unbolt the old pump, bolt on the new one, and hook upthe hoses?
07-12-2011, 04:14 PM | #18 |
It was for me. It was a simple swap with the standard mechanical OEM fuel pump. By default it was set up exactly as I needed it to be.
07-12-2011, 05:01 PM | #19 | ||
"I ain't nobody, dork."
A mechanical stock pump is just fine for Edelbrock carbs. They only put out around 5 to maybe 6 psi.
Even with an Edelbrock street type pump... it won't need a regualtor. I run Carter mechanical "street" pumps., Consistent 6 psi all day long. No regulator needed. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
07-12-2011, 06:00 PM | #20 |
07-12-2011, 07:09 PM | #21 |
Do I need to pinch off the fuel line coming from the tank? In other words, If I unhook the fuel lines, will the I drain the tank?
07-12-2011, 08:08 PM | #22 |
Ive had it apart a few times to clean it, flushed the tank etc
Maybe i''ll puller about and re set floats etc
07-12-2011, 08:39 PM | #23 | |
Registered Truck Offender
Guys guys guys guys!!!!!
Don't take my word for it,, listen to EDELBROCK... http://www.edelbrock.com/automotive_...mps_main.shtml Their Victor pumps make 8.5-9psi. The only Edelbrock pump to NOT need a regulator is the RPM street pump (#17000 and 17001 which produces 6psi NOW,, read the Edelbrock Performer series manual. http://www.edelbrock.com/automotive_.../1000/1407.pdf ESPECIALLY page 8 where it says Quote:
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
07-12-2011, 08:50 PM | #24 | |
By the way I bought a fuel pressure regulator and was going to mount it on the firewall and after I installed the new pump I didn't bother. Once I had the new pump, and put in more than one filter (on before the pump and one after) I had no problems with a flooding 1406.
07-13-2011, 12:54 AM | #25 | |
