Sway bar? Need help
i was just wondering if a sway bar is necessary on a 1970 swb c10 chevy?
I mean did the factory ones come with one? cause i dont see one on mine thanks |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Sway bar? Need help
it would greatly help your roll effect if you had one.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
swaybars were an option on these trucks
if you are going to use it old school on fam lots and backroads and keeping it under 40mph you dont need a sway bar // if you plan on highway aand other paved road type of drivin use a sway bar it is a great upgrade
Senior Moment
![]() Join Date: Mar 2002
For the money its the best up grade you can make
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
its all about the +6 inches
not needed, but it helps a lot.
I noticed a WORLD of difference after I installed one. I got mine off a 76 half ton Chevy.
-Scott- |
Just picked one up! wrecker score. have to drill out the big a55 rivets now.
I hear I need brackets because the truck is lowered.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
the boat guy
you don't NEED a sway bar, like you don't NEED shocks. Best upgrade for the money hands down.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
Its a Truck Thing......
Will not own one of these trucks without putting a sway bar on. You can get all the parts from the yard cheap, put in new bushings and BAM.....Its ON......
I usually pull them off a 73 and up, get the bar, brackets and your set. The brackets have to have the rivets removed from the frame. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
Florida Edition
![]() ![]() Join Date: Oct 2010
Got this setup from CPP. Greaseable!
And not expensive.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
thanks guys mine doesnt have the holes to mount these on...does that mean i have to drill?
all frames have the front hole but on trucks that didnt come with one from factory the cross member bracket rivet in the rear hole that youll need to use
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
