Old 07-11-2011, 08:04 AM   #1
MBEXHAUST
MBEXHAUST's Avatar
cracked windshield
I found a crack in the windshield this weekend, no stone chip to start. it just started under the rubber on the passenger side and is now 6" long just over the weekend.
I guess the window could have been damaged under the rubber that I did not see for this to happen..... Is this normal for these trucks?
Thanks MB
MBEXHAUST is offline   Reply With Quote
Old 07-11-2011, 08:57 PM   #2
PGSigns
PGSigns's Avatar
Re: cracked windshield
Does not happen often but is does happen. I have one that started like that in the windshield of my camper. Started last winter when it got real cold here and now is a foot long.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-12-2011, 10:31 AM   #3
MBEXHAUST
MBEXHAUST's Avatar
Thanks . I hope its not a problem after I install a new windshield.
Old 07-12-2011, 11:05 AM   #4
Bears63
...just another truck junkie..
Bears63's Avatar
No, it is not normal for any vehicle. I've had '63's for many years and they both still sport the same windshields they had when I bought them. The glass could have been chipped on the edge when installed, or you could have had a stone hit on the seal and cause unnoticed damage. There is a myriad of ways that crack could have started.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 07-12-2011, 11:44 AM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
It might be worth reading what the 1960 Chevy Truck Shop Manual offers about windshields that crack at the edges. I probably wouldn't go through all the trouble they describe, but a close inspection of the area where the crack started is probably in order:
Old 07-12-2011, 12:09 PM   #6
A.T. RockDriller
A.T. RockDriller's Avatar
MB..
I'm sure you already have a plan in place, but I had a similar short crack..5"-6" long and saved it with a Permatex WS repair kit......
I got lucky....... and not knowing the cause of your fracture, you may or may not be able to save it.
However, if your windshield is a nice one....save for the crack...It might be worth trying.
The windshield repair kit I used said it wouldn't work on anything like the crack I had, but I tried it....and ..."Yippee".
I started on the leading edge and worked outward by moving the cup and syringe a couple inches per injection.
Not a bad $10 save.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 07-12-2011, 12:15 PM   #7
El Campo
El Campo's Avatar
If u decide to replace windshield at some point and have the chrome trim be sure your glass shop knows what they are doing! I took mine into a pretty experienced shop and they still did not know how to put it in correctly and cracked my perfect factory glass!!! Ask them if they have done some of these in the past (and make
Sure they have done a bunch of them before u trust them with your good glass). Apparentlu there is a different technique for chrome trimmed windshields.. Just my .02.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
