Old 07-11-2011, 12:52 PM   #1
83c10wit454
83c10wit454's Avatar
Missing something for my porterbuilt setup??
So I already have the crossmember and trailing arms from nate. I'm wondering what keeps the rear end from spinning, I'm guessing the u bolts don't exactly accomplish that. I also have a panhard bar from qar and will be running bags over axle. I believe I need more than just shocks to complete my setup. Help please! Thanks
83c10wit454 is offline   Reply With Quote
Old 07-11-2011, 02:32 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Missing something for my porterbuilt setup??
The trailing arms will become a fixed mount when attached with the u-bolts... this will keep the axle from rotating under load.
Sounds like shocks are all that's left.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 08-12-2011, 12:43 AM   #3
83c10wit454
so no perches or anything? just arm directly to axle tube correct?
Old 08-12-2011, 09:07 AM   #4
texastrendz
What year truck are putting these arms on?
Also what style/year rear end is it?
texastrendz is offline   Reply With Quote
Old 08-12-2011, 11:17 AM   #5
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Your axle should have perches... If not, you'll need to weld them on! If it's for the truck in your avatar, you most likely have a leaf spring set up. If your switching to the trailing arms, you will need to mount the correct perches under the axle for the TA's to properly mount. UNLESS... Nate designed it to be used with the factory perches on a leaf spring set up!
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 08-12-2011, 11:20 AM   #6
PBFAB.COM
PBFAB.COM's Avatar
There should be a mounting pad welded to the bottom side of the axle tube that the trailing arms bolt up against. If you don't have any, get in touch and I can get you a set!
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-18-2011, 11:37 AM   #7
83c10wit454
Hey sorry about the late reply. But the truck im dropping is a 68 gmc. And the rear end is a from a late 70s early 80s c10. So if the my rear end didnt originaly use trailing arms do i hafta do some mods?
Old 11-18-2011, 11:46 AM   #8
PBFAB.COM
PBFAB.COM's Avatar
Since the rear end is a 10 bolt set up for leav springs, you will need to remove the leaf spring mounting pads and install some trailing arm mounting pads. We also have a different lower shock bar for the truck 10 bolt.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-18-2011, 12:04 PM   #9
83c10wit454
Nate
Its actually a 12 bolt with leafs. Guessing in might be more mid 70s if that sounds right. And were might i be able to find mounting pads for trailing arms?
Old 11-18-2011, 12:06 PM   #10
PBFAB.COM
PBFAB.COM's Avatar
We offer mounting pads for the trailing arms as well. Just shoot me an email with your number and I will get in touch.
nathan@porterbuiltstreetrods.com
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
