Old 07-11-2011, 03:22 PM   #1
Andyboy
Andyboy's Avatar
which spark plugs to use
My v6 305E has AC 45xls on driver side and AC 45s spark plugs on pass. side. Which ones should I stick to, maybe there even the wrong ones. All you V6 305ers please help. What are you guys running on your 305's. Thanks
Andyboy is offline   Reply With Quote
Old 07-11-2011, 03:52 PM   #2
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: which spark plugs to use
Spark Plug - AC - C45NS maybe???
http://67-72chevytrucks.com/vboard/s...d.php?t=433505
http://www.google.com/custom?domains...D%3A1%3B&hl=en
http://talk.classicparts.com/showthread.php?t=404
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 07-11-2011, 06:48 PM   #3
Andyboy
Andyboy's Avatar
OK the cross reference for the AC45xls in autolite is the autolite66. The difference between the AC45xls and the AC45s is the reach. The 45s' are hi-pref. and there fatter and shorter thread. Maybe someone here can tell me why someone would put these to different sparkplugs. Maybe something to do with the cylinders? I don't know just guessing hope someone can help. Thanks
Old 07-11-2011, 08:09 PM   #4
Rich 5150 69
Rich 5150 69's Avatar
Probably couldn`t find matching plugs,,,best guess...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 07-11-2011, 08:53 PM   #5
1Bad62Pro/Street
Andyboy,
Jump over here at 6066 GMC Trucks:
Information About Spark Plugs
http://www.6066gmcguy.org/SparkPlug.htm
GMC Big Block V6
www.6066gmcguy.org/gmcv6a.htm
http://www.6066gmcguy.org/GMCTruck.htm
Old 07-11-2011, 11:12 PM   #6
Andyboy
Andyboy's Avatar
Originally Posted by 1Bad62Pro/Street View Post
Andyboy,
GMC Big Block V6
Yeah the site is set-up different just too many email, or i was just in the wrong place. Thanks anyways.
Old 08-15-2020, 12:56 PM   #7
GJB
Active Member
Old thread, but curious if someone had an answer for this question as I have the same one. Just looking for the correct Delco plugs.
GJB is offline   Reply With Quote
Old 08-15-2020, 02:51 PM   #8
MusicMan70
MusicMan70's Avatar
Here is some info from one of the threads over at 6066GMC about the long and short threads on the plugs.
https://6066gmcclub.com/showthread.p...ht=spark+plugs
and an explanation excerpt:
the fact that 73-74 379, 432 and 478M V6 engines use a short tapered plug which was originally the AC R43T plug superseded by the AC 10 plug which I have a set of and will probably never use. Other factors to consider is the newer big cubic inch head has larger valves than the stock 305D head. 379's share the same intake valves with later 305E engines(305D have smaller valves) and have the larger Magnum Sodium filled exhaust valves, while the 432 and 478 heads have the larger Magnum intake valves over the 379. To find out which later model head you have a look at the intake and exhaust port sizes will determine that. 379 heads have the smaller ports like the 305. 432 & 478 are the big port Magnum heads, I think your best bet is to find a matching set of heads. I would also like to mention that not all 73-74 478M engines used the short tapered plugs. A replacement crate engine built in 73-74 could have the 3/4 long reach plugs for older applications. I have a late 73 478 that came out of tilt cab TM7500 series with the short tapered plug while the 74 478M in my 68 was a new replacement crate engine that came out of a 63 6500 series tilt cab and came with the 3/4 long reach plugs
RockAuto has these AC Delco plugs listed
https://www.rockauto.com/en/catalog/...park+plug,7212
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
