rotted floors/rockers
I need cab corners in my '71 C10 LWB stepside, inner and outer rockers and atleast 6-7" of each support mount (close but not including the body mount)
The rockers are rotted about an inch into the floor area, rest of floor is good. What order should I begin welding all the new panels in? Should the support pieces be last or first? Thanks |
Old Skool Club
![]() Join Date: Jun 2001
Re: rotted floors/rockers
Good question. I'll send this.....
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Grandpa in the rustmobile...
check out youtube i saw some good videos on there awhile back someone posted the links but i lost em
efabman or something has good DVDs on these trucks rust repair
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
you can do it either way but i put supports in last as i am most concerned about getting the rocker where i want it for good door gaps
formerly cooter |
I've got the same job coming up on mine, I had planned on doing the rockers first, as shocker said, to get my door gaps correct and for straigtness. Then the floor and supports. Good luck with it!
Rob 72 C/10 (under reconstruction)(destruction ? LOL) 48 Willys CJ2A 1952 Super "A" Farmall (Grandfather's) |
Im working on the same project. The local resto guy recommended starting on inner rockers, checking the fitment, then supports, then the rest. Sounds like this is the same information! Good luck and happy resto!
Trevor "You already said spite" |
Now it's getting confusing. Should I assume there is no exact procedure?
Old Skool Club
Oh, the guy is ebfabman. He has videos on "how to" for these trucks. He's a member. Do a search from the Members List, above.
![]() Join Date: May 2011
Check this link out, rocker replacement 101 in FAQ http://67-72chevytrucks.com/vboard/s...d.php?t=271066
71 c20, 350/automatic 71 K5 Blazer, 350 3 speed (really my 16 yr old sons)http://67-72chevytrucks.com/vboard/s...d.php?t=686111 71 GMC build thread; http://67-72chevytrucks.com/vboard/s...d.php?t=468765 47 Chevy Aerosedan, 403 Olds/350 turbo 69 Camaro, 307/powerglide 06 Silverado Z71 |
