Old 07-11-2011, 10:03 PM   #1
JJanzen
JJanzen's Avatar
Factory Air Blower Motor/Fan
I recently got my factory ac up and working on my 72 DD and am happy with the cold temperature of the air but not the volume of the air/fan speed. I heard one time that a fan/motor out of a 73-87 was a direct fit and would significantly supply more volume. Does anyone know about this and does anyone have any results or comments? Thanks.
Blue72
Red72
JJanzen is offline   Reply With Quote
Old 07-11-2011, 10:47 PM   #2
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Factory Air Blower Motor/Fan
I'd like to know the answer to that also.... the stock unit is fairly anemic.
Zoomin is offline   Reply With Quote
Old 07-11-2011, 11:53 PM   #3
nightmare
nightmare's Avatar
would like to know too
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 07-12-2011, 12:12 AM   #4
IndyRich
IndyRich's Avatar
Not to turn this into a for sale ad. (I previously tried and had no takers) I have 2 NOS AC Delco blower motors that I thought were 73-87. If someone knows for sure the part numbers, I'd love to know. Seems there were a ton of blower motors AC made and they are not always easy to identify....also seems the same blower was used for different models with different numbers. This is what the ones I have look like..
IndyRich is offline   Reply With Quote
Old 07-12-2011, 12:24 AM   #5
into69z
"brand new second-hand"
into69z's Avatar
Found this-not sure if it helps-I didn't like the way my fan was blowing on the 69, so I took everythng out and found the fan "wheel" that mounts to the fan motoer shaft was spinning-the metal piece that is in the fan wheel used to mount to the shaft spins free on the round fan itself-hope that makes since
anyways here's what I found:
Mechanical Catalog
Item Number MSRP Core Price Price
22098831 $59.50 $0.00 $47.60
Hvac - Controls - Blower motor
Blower motor, caballero, el camino, w/5.7l diesel 1984
Add to Cart Contact Us
Blower motor, all models, w/o ac 1984 - 1991
Blower motor, buick, w/o ac 1984 - 1990
Blower motor, chevrolet, w/o ac 1984 - 1990
Blower motor, oldsmobile, w/o ac 1984 - 1990
Blower motor, pontiac, w/o ac 1984 - 1989
Hvac - Controls - Auxiliary heater & ac - Blower motor
Blower motor, all models 1984 - 1990
OEM Catalog
Hvac Controls Blower motor w/5.7L Diesel
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 07-12-2011, 12:31 AM   #6
IndyRich
IndyRich's Avatar
Well thats interesting ...they all say w/o AC except for the last one which says:Auxiliary heater & ac - Blower motor
hmmm....its things like that, that confuse me
Old 07-12-2011, 12:38 AM   #7
leddzepp
Moderator
leddzepp's Avatar
Make sure your cowl vent door is closed, and your kick panel vent door is open when the A/C is on. If that kick panel door is shut (the recirc) your air volume will be reduced tremendously.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 07-12-2011, 12:46 AM   #8
IndyRich
IndyRich's Avatar
"If that kick panel door is shut (the recirc) your air volume will be reduced tremendously. "
Today 12:31 AM
Why would the volume be decreased? Wouldn't it just be pulling air from the cab instead of outside? It would seem that wouldn't restrict airflow enough to decrease the volume of air to reach the blower motor. I'm not saying I'm right just thinking out loud.
Old 07-12-2011, 12:52 AM   #9
leddzepp
Moderator
leddzepp's Avatar
Today 12:31 AM
It does, try it for yourself and see.
If his temperature is cold, then the cowl door is probably shut, as well as the water bypass valve closed. The cowl door lets in outside air. The passenger kick panel controls the recirc (pulls air from inside the cab)
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-12-2011, 10:22 AM   #10
JJanzen
JJanzen's Avatar
When you reference the "kick panel vent door" you are referring to the passenger side aren't you? Thanks.
Joel
Blue72
Red72
Old 07-12-2011, 10:47 AM   #11
leddzepp
Moderator
leddzepp's Avatar
yes, passenger side kick panel vent is open when the ac is on. drivers side kick panel vent closed.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-12-2011, 10:52 AM   #12
JJanzen
JJanzen's Avatar
Is there a way to check to see if the cowl vent is open or closed without taking off the cowl? I haven't looked at it yet but thought I would ask. Thanks.
Blue72
Red72
Old 07-12-2011, 11:19 AM   #13
leddzepp
Moderator
leddzepp's Avatar
yes, just look through the louvers, it is in the corner on the passenger side.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-12-2011, 01:27 PM   #14
into69z
into69z's Avatar
I was thinking the same thing! I also thought that you could change the "squirrel cage" on the fan motor just like you would change the radiator cooling fan from a four blade to a seven blade-I just don't know which later model "fan cage" pushes more air and will fit in our housings. Maybe a suburban has a different fan or a little smaller cage that will turn more rpm's.
Steve
67 Camaro
96 Impala ss-sold
b69:
Old 07-12-2011, 02:39 PM   #15
mikemileski
Check out what this guy has to say in post #5 of this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=166446
Mike Mileski
Tucson, AZ
mikemileski is offline   Reply With Quote
Old 07-12-2011, 03:16 PM   #16
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I wonder if you could supply the blower with power through a relay to the battery like the headlight mod and get more rpm's that way?
Old 07-12-2011, 08:15 PM   #17
ls1nova71
ls1nova71's Avatar
GM already thought of that, and that's why A/C trucks have a relay on the right side of the heater box.
ls1nova71 is offline   Reply With Quote
Old 07-12-2011, 08:37 PM   #18
leddzepp
Moderator
leddzepp's Avatar
I have never had a problem with air volume from a factory A/C system. Check for any leaks in the vent hoses, also check the flapper on your diverter box. Check the airflow at the heater floor duct. Have you capped off one end that feeds the center vent?
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-12-2011, 09:37 PM   #19
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Oh they did, eh? Well, have they tried hooking the blower to 6 batteries hooked in series?
