Anyone running a 12" rim out back?
I was just wondering if anyones running a 12" rim out back? I did some measurments and the stock wheel wells look to be wide enough. If so what is your rim specs? Im looking to run a 20x12.
Pics also help too ![]() |
Re: Anyone running a 12" rim out back?
track tires are 27X13 is my back tire overall size. rim is 15X12
alloy rims are all 18X10
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
anyone else??
You'll most likely need to mini-tub the wells for a 12" wheel if you've dropped the truck. Check out 69chevyshorts build thread....
http://67-72chevytrucks.com/vboard/s...d.php?t=293455
![]() Join Date: Oct 2006
Im running 12" wide rims with 29x15.50-15 tire. The bed has been cut to allow the wide tire.
Still Just Havin Some Fun!
![]() Join Date: Jun 2007
18" wide rubber on mine with 14" wide rims... Tubbed an extra 4 inches.
a green one with some stuff done to it.... |
perfect thanks a lot guys
Project 7dos
Can we get full pics of both trucks? They look nasty!
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
![]() Join Date: Apr 2005
I'm running 20 x 12's on the rear of my 68, with a 7" BS and mini-tubs. You can check out my build thread below for more information.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 07-14-2011 at 06:05 PM. |
I've posted these before. However, never pass a chance to show it off.
![]() and one from today, the trucks first rain storm... ![]()
and let me mention 18" wide tires don't do well on wet roads...
Luv fat tires. Rear rims are 12" with 7"bs. Dosent tuck as well as a fleet side, might tub it next year
#13 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#14 |
