Old 07-12-2011, 08:31 PM   #1
Gianyveedub
Gianyveedub's Avatar
Straight Six to V-6 GMC
Hey everyone. Well the S^$t hit the fan today. I need a new motor. The truck originally came with a straight six, but I have a buddy who has a GMC v-6 for $100. I was wondering what would be needed to put this big V-6 into my truck. I have the v-6 bellhousing by the way.
Gianyveedub is offline   Reply With Quote
Old 07-12-2011, 09:20 PM   #2
Woogeroo
Re: Straight Six to V-6 GMC
I'd start by looking around on this page here:
http://www.6066gmcguy.org
-W
Woogeroo is offline   Reply With Quote
Old 07-12-2011, 10:04 PM   #3
Corts60
Just here to tinker
Corts60's Avatar
Nice! I approve. The mounts and maybe the rear crossmember are all I can think of if you already have the bellhousing.
Old 07-12-2011, 10:42 PM   #4
100%Chevy
Funny you should ask!
I've pulled the I/6 from my 64 GMC and have just put a 351 GMC V/6 in!
You have to have the V/6 bellhousing,which you say you have.And you need the V/6 rear mounts(takes a 5/8" bolt).Then you need the complete front mounts from the V/6,frame stands and all.The I/6 or V/8 stands won't work!My I/6 rear crossmember works.
After this stuff,you have to re-work the engine wiring to reach.Hoses.Exhaust.
And,make sure your trans will fit the GMC bellhousing!
And be careful!That V/6 weighs about 840 lbs.!
I'll put up a pic in a minute.
Click on pictures for larger image.
Mike.
100%Chevy is offline   Reply With Quote
Old 07-12-2011, 11:16 PM   #5
monolith
Zero Albedo
monolith's Avatar
I hope this doesn't violate board policy- (just trying to help out):
I'll be pulling a siezed 305 V6 out of a parts truck within the next week or two and I may be able to supply the rest of the parts you need to get the job done if your friend doesn't have them.
Again- not trying to be mercenary here- just trying to help with what may end up being hard to find parts.
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
Old 07-13-2011, 12:25 AM   #6
Corts60
Just here to tinker
Corts60's Avatar
100%chevy-
I wish I had your cherry picker.
Giany-
Look in my signature for the clutch replacement thread, there are a lot of good pics of the V6 rear mount set up. If you need p/n's, let me know.
Old 07-13-2011, 01:53 AM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
For reference, here are photos of the V6 frame brackets and engine mounts:
Old 07-13-2011, 08:55 AM   #8
100%Chevy
Markeb01-yours are for 60-61-62 trucks with torsion bar suspension.
Mine are for 63-64-65-66 with coil front suspension.
4x4's are different too.
There's also a front center mount.
Here's some pics of the different front stands,
The shiny black ones are I/6,ones in the middle are V/8,the ones on the right are V/6.
Mike.
Old 07-13-2011, 09:46 AM   #9
markeb01
Senior Enthusiast
markeb01's Avatar
Good to know. I didn't realize GMC ever changed their frame mounts. Thanks for posting.
Old 07-13-2011, 08:49 PM   #10
100%Chevy
I wish there were a place where we could store this stuff for future refference!
These trucks looked so much alike for the 60/66 generation that it's assumed there the same.
But GMC had to be different!
Mike.
Old 07-13-2011, 08:54 PM   #11
100%Chevy
Corts60-
That's the only way I could move the engine!
I have no front suspension on the truck and that part of my shop has a dirt floor.
No way I could roll the lift to it.
Just do what you gotta do!
Mike.
Old 07-17-2011, 12:04 PM   #12
Gianyveedub
Had a change of plans. I ended up not getting the v-6, instead I found a 292 for sale. I did search the forums, but did not find the answer I was looking for. I know the perche for the 292 passenger side is shorter, but Can I still use the 230/250 perch for the 292 or will there be some huge problem? Thanks
Old 07-17-2011, 03:34 PM   #13
monolith
Zero Albedo
monolith's Avatar
I'm pretty sure that the passenger side mount is a 292 specific part.
Baz
68 Dodge Charger
