07-12-2011, 10:24 PM | #1 |
Laying frame exhaust help....
Hay guys Im needing some help from all you guys with realy low trucks I got a 62 swb with Air ride when aired out Im about 2" off the ground is there a good way to run the exhoust maybe outside the frame rails????
Thanks for all your guys help Last edited by bobber80; 07-12-2011 at 10:32 PM. |
07-13-2011, 12:09 AM | #2 |
1961 crewcab
Re: Laying frame exhaust help....
couple ideas..
fender well headers just route the exhaust through the fender well and then behind the rocker... seems like you should be able to punch a hole in the frame rail, and run the exhaust through there, I would box and plate the section w/ the hole though...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
07-13-2011, 10:33 AM | #3 | |
It's Better With Nitro
07-13-2011, 01:27 PM | #4 |
I was going to run shorty headers then turn out behind control arms but I ended up going with full length headers and through the crossmember then out the side of the frame.. My front crossmember is about that low but the back limits me with the stock floor.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
07-18-2011, 12:37 AM | #5 |
Thanks guys I new you guys would have some info......
07-18-2011, 12:41 AM | #6 |
Hell yeah!!!
Any competent muffler shop should be able to route it anyway you want.
Stock is good but custom is the sh*t! |
09-23-2011, 08:12 PM | #7 | |
09-23-2011, 09:04 PM | #8 |
you guys have it easy. I have to figure out how to route 4" diesel exhaust down the passenger side, and dump it as far away from the cab as possible.
09-24-2011, 02:12 AM | #9 |
09-24-2011, 08:15 AM | #10 |
A 65 swb on bags with a 12v cummins. I'm in east Orlando. But I'm building the truck at my dad's shop in winterhaven.
Posted via Mobile Device |
09-24-2011, 10:58 AM | #11 | |
I've done a couple ISB conversions and routing the downpipe from the turbine is not too bad since it is on the passenger side of the block. One we did as a stack through the bed and the other was routed on the outside of the frame rail, exiting in front of the passenger rear tire. The Cummins exhaust is a lot simpler than the PS and Duramax conversions.
