Old 07-12-2011, 11:38 PM   #1
cpisani70@aol.com
cpisani70@aol.com's Avatar
Brake trouble
So I have been struggling with my new truck for a while, if ever I have to make a quick stop or God forbid it's raining when I stab the brakes the backs instantly lock up! Does anyone know where to start, I would like the front and back to be equal. The truck is a 71 Custom Camper 20
cpisani70@aol.com is offline   Reply With Quote
Old 07-13-2011, 09:37 AM   #2
geezer#99
geezer#99's Avatar
Re: Brake trouble
You might have gotten some brake fluid on the pads. Or grease. Pull the drums and look for a wheel cylinder leaking.
Old 07-13-2011, 12:05 PM   #3
Stricklinator
Stricklinator's Avatar
Re: Brake trouble
I think Geezer is right, I had this problem many times with rear drive patrol cars (caprice) and it was always a leaking axle seal somewhere.
Paul
1969 C/20, 307, 4-speed, rusty with manual steering and brakes!
Stricklinator is offline   Reply With Quote
Old 07-13-2011, 07:14 PM   #4
cpisani70@aol.com
Re: Brake trouble
Thanks for the input I will start there and keep you updated
Old 07-13-2011, 07:18 PM   #5
DT1
DT1's Avatar
Re: Brake trouble
Sounds like the proportioning valve.
DT1 is offline   Reply With Quote
Old 07-13-2011, 07:35 PM   #6
cpisani70@aol.com
Re: Brake trouble
DT1 that was my first thought maybe because it isn't one wheel it's both. So is the valve adjustable or do I need to buy a new one? If so do I buy an exact replacement or something else?
Old 07-13-2011, 10:13 PM   #7
DT1
DT1's Avatar
Re: Brake trouble
You should still check to make sure that you don't have a leaking wheel cylinder.
Even a small leak in one of them can compromise the rear system and cause both to lock up in a panic stop.
Also, make sure your brake indicator light is hooked up and working. If you're NOT getting an indicator at the dash the valve is probably adjusted right.
If you are getting a light, you will have to bleed the system to re-center the pin until the light goes out.
You can also install an aftermarket, adjustable valve that you can dial in to suit your preference.
Old 07-13-2011, 10:46 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
Re: Brake trouble
I am rebuilding the brakes on my C-20 right now. The right rear wheel cylinder is leaking and both axle seals appear to be leaking. The front shoes were worn down to the rivets and the rears were worn through the shoes and into the metal backing... I will be replacing all of the above. I have been getting my parts at my local NAPA Store. They also turned my brake drums for me. So far so good.
LockDoc
Leon
