07-13-2011, 01:09 AM | #1 |
need help with trans linkage!
im putting a hurst linkage on my saginaw 4 speed and for some reason the
1st/2nd arm hit reverse arm before it can go into 1st, when it does this the pushes the revers arm into reverse, does anyone have a pic of how the hurst comp plus linkage should be set up?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
07-13-2011, 11:47 AM | #2 |
Re: need help with trans linkage!
You probably have the reverse arm on the trans wrong. If I remember correctly the 1-2 and the 3-4 arms face up and the reverse faces down
07-14-2011, 03:14 AM | #3 |
iv tried that but it wont bolt up right to the tranny
