Old 07-13-2011, 10:19 AM   #1
Russell Ashley
Russell Ashley's Avatar
57 front fender mounting ???
Quick question: Should there be a rubber spacer between the fender and cowl at the upper rear mounting bolt of the front fender?
I think my truck had solid shims but the FSM mentions a "cushion".
Russell Ashley is offline   Reply With Quote
Old 07-13-2011, 11:44 AM   #2
Kim57
Kim57's Avatar
Re: 57 front fender mounting ???
On mine I'm using solid shims. I don't remember finding rubber ones when I took it apart but that was so long ago I could have forgotten.
Kim
Kim57 is offline   Reply With Quote
Old 07-13-2011, 01:58 PM   #3
55metalmonkey
my 55 just had shims, almost makes sence that there should be a very thin rubber washer in there.
55metalmonkey is offline   Reply With Quote
Old 07-13-2011, 08:28 PM   #4
oletrux
oletrux's Avatar
Mine's shimmed too.....don't know if that's correct, but it is what it is....
oletrux is offline   Reply With Quote
Old 07-13-2011, 10:18 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
It should be just a metal shim, no rubber. The only place there is rubber is in the rear cab mount, a very thin piece on a shim on the front cab mount, more of a anti squeak device, lower radiator support and the lower front and rear of the fender wells.
dwcsr is offline   Reply With Quote
Old 07-14-2011, 07:55 AM   #6
Russell Ashley
Thanks Guys. I'm getting ready to put my fenders back on and want to do it like it should be. I was using the LMC catalog as a guide and have all the new rubber parts shown there but the word "cushion" in the FSM made me wonder.
Old 07-14-2011, 06:09 PM   #7
OrrieG
OrrieG's Avatar
Also a strip of sealant between the inside of the fender at the door jamb and the cab, and a rubber seal along the length of the back (cab) side of the inner fenders. The Factory Manual has a couple of pages devoted to just sealing, lots of stuff that was either missing or I did not pay attention to during disassembly too.
OrrieG is offline   Reply With Quote
