Old 07-13-2011, 07:36 PM   #1
1968CHEVYC10
1968CHEVYC10's Avatar
Exhuast studs
Just swapped a 6.2 diesel into my '68. When I went bolt in some exhaust, I noticed, on the studs you bolt the pipes to, only about an Inch is threaded, so you can't turn the nut down far enough. So I'm guessing I need some kinda spacer, just wondering if this might be a mass produced part or if I need to make something myself?
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 07-14-2011, 10:17 AM   #2
RustyParts
RustyParts's Avatar
Re: Exhuast studs
I think there was a nut and spring for the newer exhaust systems. Check out this website.http://www.autozone.com/autozone/acc...g-Kit/_/N-25ui
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
