04-04-2003, 01:16 PM | #1 |
HEI install
Can someone give me a step by step to install an HEI where my points dist is? What do I tap into for power? Thanks!!
04-04-2003, 01:31 PM | #2 |
Check the FAQ board.
Just make REAL sure that you use a large enough wire and tap into switched, full 12 volt power. Good luck! Jeff
Jeff '67 short Fleet; my ongoing project. '66 long Fleet; my original "baby." Live life or bust trying. |
04-04-2003, 01:47 PM | #3 |
its all about the +6 inches
And here is the link... http://67-72chevytrucks.com/vboard/s...threadid=13698
04-04-2003, 04:23 PM | #4 |
If you remove the old resisitor wire there is 12 volt's there. just pull out the old reistor wire and plug in the new power wirefor the hei. That's how I did mine looks nice and factory too.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
04-04-2003, 08:26 PM | #5 |
Thanks!!! Got her fired up today!!!!!
