78K & 79C Jimmys
How to go topless
I'm looking for ideas to make a top come off with one person
thinking handles on the outside would work(two each side) would be good for two people since my buddy can't lift to high then maybe using ropes then to the handles, some how lifting the top by myself also thinking someway to lift,jacking up cap from in the bed to slide saw horse type stands in under the cap lips then drive out or back in..... or how do you do it
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Re: How to go topless
was a thread by tv blazer I think
laying low
![]() Join Date: Mar 2001
Provided you have a shop or garage. You could screw 4 eyebolts into the rafters, 2 on each side. Then use 1 inch wide ratchet straps hanging off each eyebolt. Place the hook just under the lip fore and aft on each side and ratchet it up. You could do much the same with a rope and pulley system.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
78K & 79C Jimmys
I don't fit in the garage lol
thats kinda what i was thinkin just a frame tho to drive threw eyelets in the roof to lift from not much room for handles thinkin somebody musta done something
On my old 76 I took it off myself. Slid it back on the bed rails until I could tip it off and lower it. Pretty sure I used a hand truck to move it around after that.
Now I have a 91 and the top seems to be a lot heavier than the old one. I don't know if they are different, but I wouldn't try it with the current top. Maybe I got a lot weaker over the past 5 years ![]()
Curry in a Hurry: SB rebuild for my 71 C20 |
Ridin' Dirty
1-drive between a few saw horses,
2-slip a few 2x4's across under the top, over the saw horses 3-deflate air ride 4-drive out! ![]()
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
#7 | |
78K & 79C Jimmys
no air ride so i just lift one end then the other
#8 | |
I know the pieces fit
#9 | |
78K & 79C Jimmys
simple lift onto a saw horse make ones with those orange ajustable brackets like for painting pushing up from inside should work,slide a board threw
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
#11 | |
78K & 79C Jimmys
duno if i'd lift it without/support washers in those holes both involve a garage....not happening in mine i can't back in ,and i sure don't have room to roll it in and out
I made this from an old ping pong table and some scrap plywood.Makes it nice to be able to take it off by myself and move it around.
![]() ![]() ![]() 77 k5 2wd 76 k5 jimmy 4x4 97 c1500 2wd 06 chrysler 300 on 22"s |
#13 |
heres how i get mine off the blazer i used anchors and lag bolted them in use a 12' 600lb straps i pick up the back slid the strap under it. i wraped some shop rags around the strap where the top sets on it so it doesnt hurt the paint. works great im only a 150lbs myself!!
#14 |
laying low
Yeah buddy. That's what I'm talkin about. Just be careful walking in there when the top's hanging and no lights on.
#15 | ||
78K & 79C Jimmys
#16 |
lol yep works great! i just gotta remember to fold down the back seat before i pull out the garage. lol as for walking in to it in the dark im always having to duck stuff in there at least the light switch is by the door so i can allways hit it when i walk in! lol
#17 |
Low & Fast!
This is how I took mine off at my old house. Only takes one to do it..
http://www.67-72chevytrucks.com/vboa...d.php?t=258859
