07-14-2011, 05:03 PM | #1 |
parking brake cable woes 72 k-10
Im having a heck of a time finding parking brake cables for my project. Its a 72 frame and axles, dana 44 and 12 bolt rear. They are the original axles and the frame is a confirmed 72 frame by the serial numbers. Its a LWB truck. I found a NAPA part number UP92416 and got those. Everything looked and installed right except for the cable housing is abt 3-4 inches short of being able to hook into the factory brackets on the frame. The cable I have measures 29" for the housing. I need the housing to be abt 35-38" long. LMC doesn't list anything and none of the FLAPS do. NAPA list a cable for a 69 that seems to have the right dimensions, but they can only locate 1 nation wide! Can someone help????
Posted via Mobile Device Its also stock height, no lift |
07-14-2011, 08:38 PM | #2 |
Re: parking brake cable woes 72 k-10
Try inlinetube.com, If they don't have them, they will make them.
Tim |
07-14-2011, 08:43 PM | #3 |
If you can't find one, madisonpowersystems.com is great.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061 |
07-15-2011, 09:13 AM | #4 |
Thanks for the links guys!
Did a little searching and it appears that most all of the aftermarket cables available end up too short! Called up Inline Tube and ordered a set yesterday, great folks to deal with! |
