![]() Join Date: Feb 2011
Wiring for 67 GM Radio ?
Does anybody know how to hook up a stock 67 GM radio ? Pics of power ground and speaker ?
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
The Older Generation
Re: Wiring for 67 GM Radio ?
I don't have any pics on my computer but the speaker connector plugs into the back of the radio and the Red power wire from the "Radio" connection on the fuse block plugs into a terminal in the speaker connector. If you look at the speaker connector plug you will see it has two wires and hole for the power wire to plug into. LockDoc
All of the original wires are gone I need to do this from scratch. looking at the back of the radio the far right is power the next two are for the speaker and the radio grounds itself is this correct ?
The Red Menace
That is correct. When you attach the radio and speaker to the underside of the dash, that grounds it.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." |
there is a black and grren wire that is i believe permanetaly connected to the speaker then there is a red wire that connects to the fusebox and the black green wire, also the black green wire connects to the radio as well.
