Old 07-15-2011, 12:04 AM   #1
vgnope
vgnope's Avatar
time to camm-er up
im lookin into doin a cam and lifter kit on my 283.. I have my eyes set on the 2103 cam & lifter kit from edelbrock.. would just changing out the cam be ok, or would i need to get the;camshaft bearings?rods?valve springs? what would be the most efficient but inexpensive route to go?
thanks
vgnope is offline   Reply With Quote
Old 07-15-2011, 01:19 AM   #2
Captainfab
60-66 Nut
Re: time to camm-er up
For a stock 283, I would go with something like this cam
http://www.summitracing.com/parts/SUM-K1102/
it is the exact same cam as the Edelbrock 2102. That is a good all around cam for a stock engine. That cam is pretty mellow in a 350, but it should sound and perform good in a 283. I would suggest also getting a timing chain and gear set, and also valve springs and rocker arms, if those are still original. This will allow you to obtain the full benifit from the cam upgrade. You will also want to read up on the importance of proper cam break in and the need to use an oil that has sufficient ZDDP content to support a flat tappet cam. The typical oils available these days do not. Here is some reading to get you started.
http://67-72chevytrucks.com/vboard/s...d.php?t=381780
Old 07-16-2011, 02:40 AM   #3
vgnope
vgnope's Avatar
How about installing/changing out cam bearings, is it recommended?
Not with th whole valve lift stuff, is .442 much different than .420? I don't understand th whole lift at valve, exhaust, duration..
I want to hear my engine pitter-patter wen it's at idle..
What I was originally going to get cam wise was a .484, but I heard that's tooooo big for a 283..
Old 07-16-2011, 06:29 AM   #4
awbrown
To change the cam bearings the engine will have to come out .. also all the crap that settles behind the bearings would need to be washed out.. I mandate at minimum that the block is spray washed when i install cam bearings... To simply do a cam change does not warrent changing the bearings unless they are visually tore up.. I used to sell the stock 350 cam , if someone wanted an upgrade on a 283, and that was plenty of cam for that size engine...
awbrown is offline   Reply With Quote
Old 07-16-2011, 11:03 AM   #5
oldtrux
oldtrux's Avatar
i too am getting to that point with my little 283.hot tanked,mag tested,sonic tested,new pistons,cam bearings.i am thinking the eddy 2102,eddy 27034 intake,and 500 or 600 cfm carb.i think the 2102 cam will be a perfect setup.
oldtrux is offline   Reply With Quote
Old 07-16-2011, 03:38 PM   #6
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: time to camm-er up
Ahhhhhh yes.......this is what I like to her from you fellas....
This is what you need to master the CSB 283.
Once you have this combination you can unleash the full power of the 283!
http://www.summitracing.com/parts/CC...00-4/?rtype=10
This is a street combo.
COMP Cams K12-600-4 - COMP Cams Thumpr Hydraulic Flat Tappet Cam and Lifter Kits:
Cam/Lifter, Valvetrain, Hydraulic Flat Tappet, Advertised Duration 279/297, Lift .479/.465, Chevy Small Block
http://www.summitracing.com/parts/CCA-K12-600-4/
Good luck! Unleash the 283 beast!
www.compcams.com/Thumpr/index.html
This is what my dad put in his 283. They dynoed it just a little over 300hp.
www.fultoncompetition.com/
Baddeset sounding 283 I have ever heard!!!!!!!
Can you guess what kind of heads are on there?
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 07-16-2011, 03:57 PM   #7
oldtrux
oldtrux's Avatar
Smile Re: time to camm-er up
ha ha ha,good one bad 62.hey with this combo i should have an earth shattering 250 horsepower,lol we know,we know you have the monster power!i just wanna cruise with decent fuel mileage.cheers or shall i say guzzle!
Old 07-16-2011, 04:09 PM   #8
1Bad62Pro/Street
Ha ha.... yea
My dad wanted something different and unique so he took the 385 stroker out of his rambler and now he has that bad 283 with 300plus HP in her!
Captainfab is on the right track
When ya get her and put her back together let us here it!
Hey.....Dual Pattern Cams sound nice!
Last edited by 1Bad62Pro/Street; 07-17-2011 at 04:04 PM. Reason: http://www.youtube.com/watch?v=7XeJJeMBl0I
Old 07-16-2011, 05:48 PM   #9
Pop's C-10
Pop's C-10's Avatar
Fresh valve seal would be a good idea being you pullin tha springs anyway..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 07-17-2011, 02:16 AM   #10
vgnope
vgnope's Avatar
I'd like to do all Edelbrock, but hearing that comp, I'm jus bout hooked.. I'll still have to figure all the other items I'll need to get; cam bearings, pushrods, rocker arms..I'm defiantly getting new springs, and timing chain/gear set..
But if I can just change out th cam & lifters with no problems.. That's Wat I'm hoping.. Will I be ok? Or should I not cheat it and do it all?
Old 07-17-2011, 10:15 AM   #11
oldtrux
oldtrux's Avatar
i think it would be best to change everything you listed minus the cam bearings,imsure they will be fine.the only reason i did mine is because my engine was out and hot tanking and shot peening destroys them.as captain fab stated by changing the valve springs etc. you will get the full benefit of the cam upgrade.i am also struggling with cam selection,idont fully understand the whole lift,duration thing.the comp cam does sound sick but i wonder if it might be a bit much for a street driver 283..i dont know.please keep us updated with your decision.cant stop learning.
Old 07-17-2011, 03:57 PM   #12
blackedoutharley
The sensible side of me says that on a 283 this cam would probably be all you need.
http://www.summitracing.com/parts/CCA-12-205-2/
blackedoutharley is offline   Reply With Quote
Old 07-17-2011, 04:29 PM   #13
awbrown
That is the biggest cam I would use ! been there done that ...
Old 08-02-2011, 01:56 AM   #14
vgnope
vgnope's Avatar
So I just picked up the picker and stand..Wednesday will be th day I begin th draining of fluids...can't wait to get started with th tear down.. Th wife said no to engine being pulled in th garage, but Hmmmm.. I'll post pics..
Old 08-02-2011, 08:10 AM   #15
awbrown
So , what cam did you chose???
Old 08-02-2011, 09:50 AM   #16
vgnope
vgnope's Avatar
Well I didn't choose 1yet because th PO "says" he rebuilt th motor..so I'm going to pull it all out, find part#'s if any and start from there..
But I'm still in a limbo on choosing comp or edelbrock..
Old 08-02-2011, 09:56 PM   #17
pmkrew
Comp thumper cams are great, I wouldn't hesitate for a second if it's in your budget. I had a comp cam high energy in my first truck with a 283 and it was a great driveable engine, that 12-205-2 sounds like the one I had.
Keep in mind if you go big and you have an automatic you will want to upgrade your torque convertor to a stall while your engine is out, if it's a manual less problems...
pmkrew is offline   Reply With Quote
Old 08-02-2011, 11:53 PM   #18
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
i have a thumper sounds great not happy otherwise
279 (smallest)
John
1999 Toyota Tacoma 4x4
Old 08-10-2011, 09:45 PM   #19
vgnope
vgnope's Avatar
so i pulled th block, got ahold of th cam inside, its a Elgin brand cam pn# E923P.. similar to th edelbrock rv cam.. all th info i read about the cam was
ELGIN E923P Camshaft 1955-1994 283-400
.420/.443 Lift
270°/280° Advertised Duration
RPM Range 1500-4000
Good Choice for Towing
Recommend performance springs
112° Lobe Center
51° Overlap
Good to Fair Idle
204°/214° Duration at .050
So being that, im hoping that my torque convertor is not stock, since theres no pn# on it im kinda stuck.. But i did buy a pete jackson noisy timing gear set and i painted th motor.. I think im going to jump on th comp 12-206-2, and we will see how she performs..
Old 08-10-2011, 11:38 PM   #20
blackedoutharley
Excellent choice.... you'll grow to probably hate that gear drive though.
Old 08-11-2011, 12:05 AM   #21
shortbed70
shortbed70's Avatar
The gear drive is really going to suck breaking in the cam because you won't be able to hear anything but it. Get some good oil and a bottle of zddp
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 08-11-2011, 10:39 AM   #22
wildearp
wildearp's Avatar
I have run them several times. More often than not, they are too quiet. I finally have one that I can hear, and I like it.
wildearp is offline   Reply With Quote
Old 08-25-2011, 02:13 PM   #23
markeb01
Senior Enthusiast
markeb01's Avatar
I had a Pete Jackson noisy gear drive in my 350/46 Ford back in 1984, and since 1991 I've had one in my 350/1960 GMC. Can't imagine doing without it. Combined with a manual 4 speed it makes music I could listen to all day, which also explains why I don't have a radio!
Old 08-25-2011, 05:12 PM   #24
vgnope
vgnope's Avatar
Im ready to hear th music too...lol..
I flipped a coin and I got tails.. So I bought th Edelbrock 2103 cam kit.. I took th heads to a machine shop, th springs have a seat pressure of 88lbs, th valve seals are in great condition..I still need to get all th gaskets new head bolts.. My Intake valve is 1.84 and exhaust is 1.50.. Same As th 305 heads..
Anything that I should watch for during th break-in?? I kno th 20 mins @2k rpm.. Is that it??I was planning on doing it with th tranny disconnected to lesson th load on th motor... What do I do after th break-in??
Old 08-26-2011, 12:05 AM   #25
Captainfab
60-66 Nut
Be sure to liberally apply the cam assembly lube. Also add a bottle of engine break in additive to the oil. If you aren't aware of the lack of ZDDP in most current oils and the increased number of flat tappet cam failures as a result, you really should read up on that. Here are a couple links to get you started.
http://www.bobistheoilguy.com/forums...s.php?ubb=cfrm
