07-15-2011, 01:15 AM | #1 |
Been a while! figured id post some updates.
well i havent made any posts for a while so i figured it was time for some.
since i finally graduated high school yes high school hahahaha and got put on full time at the cnc machine shop i work at. ive had more time and money for the truck updates: -i milled the choke horn off my carb at my work. -cut the inner fenders ( no not the wheel wells the actual inner fender) -cut the inner besides out. - cut more core support apart (see pics) -machined custom aluminum rods with adjustable heim joints on the ends to support the bedsides since there is the inner bed, and make the besides perfectly parrallel so i can make me rescessed bedcover. -removed the front of the bed. - swapped the belltech shocks and springs out for moroso chevelle trick springs, and strange drag shocks. -no more front sway bar -finished all the wiring. - machined my own adjustable solid carb linkage. -new tubular race throttle pedal with custom bracket. -longer studs and open ended lugs in front - started my custom aluminum sheet metal bed cover (as you can see in picture only the frame is done) -head lights, tail lights, marker lights and turns signals in - custom billet grill mounts i made. ( since i hardly have a core support) and more little things that i dont feel like listing now all i need is to install my s&w anti-roll bar, finish the bed cover, get front runners and new slicks, and off the to track i go! finally after 3 years her are some pictures. |
07-15-2011, 01:16 AM | #2 |
Re: Been a while! figured id post some updates.
here are some more pics.
07-15-2011, 02:54 AM | #3 |
~Rest In Peace~
nice job ,time to have some fun ,you running on 32 inch tires ,im running 31 inch 18.50 ,take some videos when you go racing like to see it run down the track
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
07-15-2011, 07:49 AM | #4 |
Its looking good! Did you cut the factory firewall out or just make aluminum covers? If you did cut it out you need to add a bunch of bracing behind the aluminum. There is allot of strength in the factory firewall.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
07-15-2011, 11:03 AM | #5 |
i started it in 9th grade i was supposed to finish by graduation hahah. but right now there 33x19.50 m/ts but when i switch to slicks im gonna run 33x15s.
07-15-2011, 11:06 AM | #6 |
i cut some of it out, basicly the shape of the aluminum, but i left an edge enough for the rivets. since ive done so much cutting on the truck ive realized when theres a piece not worth cutting just cuz of the support its giving. i cant really explain how i did, youd understand if i took the aluminum off so you can see whats left. its still solid tho.
07-16-2011, 12:20 AM | #7 |
What part number of front springs did you use and how much did you alter them to get that ride height? Looks great.
07-16-2011, 08:01 AM | #8 |
i have the part number written down somewhere, let me check, and a trimmed about a half coil off i think it was, i also have 2.5 inch drop spindles on it, so its not just the springs. ill get back to you on that.
