Old 07-15-2011, 02:18 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
DBW components
I have a 2004 6.0 that has the DBW TB and complete engine harness. I am really considering keeping the DBW instead of the DBC set-up. I have read some of the threads here and it looks like I need the TAC and Gas pedal from the same year as the computer correct? I didn't get the computer with the motor so do I need to look for a 2004 computer as well? Where is the TAC located?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 07-15-2011, 03:28 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: DBW components
not sure....the pedal assembly?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-15-2011, 03:51 PM   #3
Jim_PA
Re: DBW components
TAC is on the drivers side of the firewall.
If you have a DBW engine harness, there should be a plug that goes to the TAC in there somwhere... most of those wires go up to the throttle body.
From the TAC, make sure you get the cable that goes through the firewall, and get the pedal too.
Jim_PA is offline   Reply With Quote
Old 07-15-2011, 06:25 PM   #4
softballnrd27
Re: DBW components
Comp, Tac and pedal from same year?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 07-16-2011, 03:32 AM   #5
ls1nova71
ls1nova71's Avatar
Re: DBW components
That would be correct. Do you have a PCM? If you do, then just get a TAC and pedal that is the same year.
ls1nova71 is offline   Reply With Quote
Old 07-16-2011, 12:23 PM   #6
softballnrd27
Re: DBW components
I have everything to do DBC but only the harness and TB that came with the motor for DBW.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 07-16-2011, 02:51 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: DBW components
then you need to get a computer, pedal assembly and tac that match the year of the motor (tb)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-16-2011, 04:27 PM   #8
ls1nova71
ls1nova71's Avatar
Re: DBW components
Throttle bodies are the same from.'30 until '07 in Gen3 engines. Just make sure what ever PCM you get that you get a.matching TAC and pedal. '
