07-15-2011, 10:07 PM | #1 |
C-20 Lower Control Arm Shaft Kit Question
I recently ordered new Moog suspension stuff from RockAuto and keep running into something strange with the shaft kits (part #K6147) they keep sending. When my first order came in I noticed one of the shaft kits was missing more metal at the threaded ends, so I compared my originals to the new Moog stuff and noticed my originals are machined exactly like the one on the bottom in both pics. No problem, so I sent the unusual machined one back to RockAuto and they sent me another one that is identical to the one I sent back.
Am I missing something??? Should I reuse the old shafts??? Did Moog have a bad run of the shaft kits that are machined wrong? Thanks in advance, Jeff
Jeff Horsman 1972 C20 Highlander "C" 1966 Olds 442 L69 four speed 1971 Skylark (GS clone racecar) 494 stroker 1986 Buick T-Type |
07-16-2011, 03:22 PM | #2 |
Re: C-20 Lower Control Arm Shaft Kit Question
You need to use new ones. Have you tried them with the caps. Sometimes after market parts vary a little. Sometimes they improve on the original & sometimes they make it to fit more then one application. Ive put a lot of them on from Moog & never had a problem. Be sure you put the indentation in the shaft on the correct end to fit the dowel at the U-bolt.
07-17-2011, 10:25 AM | #3 | |
Moog has always been great in the past, but this is strange?? Anyone else have ideas.
07-17-2011, 01:43 PM | #4 |
Scrapper 1
so many people swap out these front ends and put the newer ones in that have the press in ones and I feel these are better Fitting and cost a hell of a lot less to do then the new trucks bushings you go to a shop to have the this one done 1967--72 and to do the 1973 and later cost more
07-17-2011, 09:04 PM | #5 | |
07-18-2011, 07:59 AM | #6 |
I just did mine back in the spring, but I didn't take pics of the new stuff. If I recall right though mine had the machined surface like your new one. Its just where the grease seal rides I believe. You can slide your grease seal on to verify this. I'll look at my old ones that I saved and see what they look like when I get the chance. My new ones were 1 Moog from Turkey I think and one TRW made in USA. They both were exactly like your new one though I believe. Jim
07-18-2011, 10:09 PM | #7 | |
