07-16-2011, 03:38 AM | #1 | |
VA72C10
Dipped and Bead blasted parts like new!!!
Parts perfect for a nice truck but a must have for a high end restoration. I consider many of these parts to be superior to some NOS parts I've sold because many NOS parts have surface rust and/or a rough finish that needs removed before paint or powder. These ARE USED parts but all look and function like new!!!
I have had several of my best parts bead blasted by tll74 for my 72 cheyenne super project and sent my best extras at the same time. I took the best of my other parts and also some more I got from Randy (Teeitup) and Sharpie and had them brought back to like new condition. His process: Quote:
All prices are picked up. I will combine shipping if you purchase multiple items. I have other bead blasted parts I will be listing as well as other used parts I can combine shipping with also. Hood hinges with springs 100/pr ***I do have a couple pair that are nice but not perfectly tight for 60/pr 72 door lock actuators 80/pr super tight springs Small block engine towers w/bolts 45/pr Complete tailgate hardware in gate and on bed with bolts 120 Door hinges 100/set Grille end supports 75/pr (Fit MUCH better than the repops do!!!) Grille end supports with extra holes or loose nutserts still useable 40/pr Door latches nice and tight 55 each/ or 90/pr Body side door catches 45 each or 75/pr w/ shims & bolts/washers complete! 67-68 steel headlight bezels 80/pr 69-72 steel headlight bezels 50/pr Windshield wiper transmission 75/set 72 window regulators nice with good splines! 120/pr 71-72 parking lamp housings with pigtails (wiring like new) 80/pr Window guide channels 30 each rear wheel well Splash shields 120/pr- these are super nice!!! 69-72 e-brake 45 Lower window track (glass mounts into) 25 each a/c battery tray with battery clamp and clamp for a/c hose 150 69-70 center grille support 40 brake booster to firewall support bracket 30 Hood Hinges and Springs 72 lock actuators Grille Brackets Door latches All tailgate hardware including handle and screws/bolts Other parts (pics from Tll74 before he shipped to me)
Looking for a 67-72 swb or blazer project in or around VA. |
07-16-2011, 03:39 AM | #2 |
VA72C10
Re: Dipped and Bead blasted parts like new!!!
A couple of the parts in the pictures show light flash rust on them from humidity in transport to me. Those parts have been washed in a solution that removes it and then in a second which will prevent it from occuring.
07-16-2011, 03:41 AM | #3 |
VA72C10
It really is amazing how good this process works. The foam pieces inside the tailgate are soft again, and any wiring is soft and pliable
07-16-2011, 06:42 AM | #4 |
Hi, i have a right\left doors that has the glass and i need the rest that gos inside doors. What would be the total shipped to 35816 a business address. Thanks,buddy
07-16-2011, 09:58 AM | #5 |
Do you have a pic of the battery tray?
07-16-2011, 01:10 PM | #6 | |
VA72C10
Or the regulators (72), door lock actuators, and door latch (do you want the catches that receive them on the cab?)
07-16-2011, 01:13 PM | #7 |
VA72C10
It's in the picture above showing the other side and this one (a/c hose clip not pictured but included) I can try to get a better up close picture tomorrow if needed....trying to borrow a camera right now...mine's not working...
07-17-2011, 06:29 AM | #8 |
What is the process
07-17-2011, 07:30 AM | #9 |
One of the First
I'll take the L/R door actuators of they are 72 type.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
07-17-2011, 08:18 AM | #10 |
VA72C10
I hot tank the parts in a caustic solution (removes all the paint and oil-grease-etc.) and then dip over night or so in a acid thank that kills the rust. The third step is a simple glass bead and then the part is like new, 100% rust free.
Yes, they are 72 type with the longer shaft.
07-17-2011, 08:25 AM | #11 | ||
VA72C10
07-17-2011, 09:01 AM | #12 |
Just like to part out trucks!!
Man Jonathan, that stuff turned out real nice, good job!!!!!!!
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
07-17-2011, 11:28 PM | #13 |
I'll take the 72 lock actuators. shipping to 98230
thx, Al
1972 GMC Sierra 1972 GMC Super Custom Suburban |
07-24-2011, 07:51 PM | #14 |
I would be interested in the window channels. are they still available?
07-24-2011, 08:56 PM | #15 |
Active Member
I see u have emergency brake assembly that would fit a 69 how much and ship to 43223. Thanks Doug
07-24-2011, 11:40 PM | #16 | |
VA72C10
Sorry for the delay guys. I've been getting like 250 emails a day from the forum and honestly forgot about this thread....
The set shown here is sold. I will check if I have another set if still interested. $10 for shipping. Quote:
Yes, will fit 69-72. 58 shipped.
07-25-2011, 06:05 AM | #17 |
07-25-2011, 12:49 PM | #18 |
VA72C10
07-25-2011, 08:03 PM | #19 |
Active Member
I will take the Emergency bake assembly for $58 Thanks Doug
07-25-2011, 10:28 PM | #20 |
I will take the Complete tailgate hardware....I sent you a PM Jonathan...Thanks Dave
07-25-2011, 10:43 PM | #21 | |
VA72C10
Got it. Thanks
07-27-2011, 10:17 PM | #22 |
GobbleStalker Calls
Whats left.
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino. Stay Tuned! 1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD! 09 GMC Sierra SLT All Terrain pkg. 2014 Jeep Wrangler Sahara unlimited. ( The wifes ride ) |
07-27-2011, 11:39 PM | #23 |
VA72C10
I have multiples of several of these....here's the current list. I have some other parts I need to go through so if you're looking for something you don't see let me know. Package deals available...
Hood hinges with springs 100/pr ***I do have a couple pair that are nice but not perfectly tight for 60/pr Small block engine towers w/bolts 45/pr Door hinges 100/set Grille end supports 75/pr (Fit MUCH better than the repops do!!!) Grille end supports with extra holes or loose nutserts still useable 40/pr Door latches nice and tight 55 each/ or 90/pr Body side door catches 45 each or 75/pr w/ shims & bolts/washers complete! 67-68 steel headlight bezels 80/pr 69-72 steel headlight bezels 50/pr Windshield wiper transmission 75/set 72 window regulators nice with good splines! 120/pr 71-72 parking lamp housings with pigtails (wiring like new) 80/pr Window guide channels 30 each rear wheel well Splash shields 120/pr- these are super nice!!! 69-72 e-brake 45 Lower window track (glass mounts into) 25 each pending mhrino a/c battery tray with battery clamp and clamp for a/c hose 150 69-70 center grille support 40 brake booster to firewall support bracket 30
07-28-2011, 06:39 AM | #24 |
Im sorry , I didnt get back to you right away. I found the pair I had here at the house. Thanks again sorry for any inconvenience
09-15-2011, 02:06 PM | #25 |
VA72C10
still have a lot of these really nice parts. Planning to start painting them satin or gloss black soon at a body shop I'm working with....any more interest with them painted vs bare (price will go up $10-20 per part once painted)
