Old 07-16-2011, 01:36 PM   #1
6 Door King
Calling Guys that Tow!
If anyone has personal experience towing with an air bag setup please give me the wisdom of your trials. I am looking to find out which type of setup will yield me the best stability while still providing a decent street ride without the trailer behind me. I am considering buiding a three link setup with the bags behind the axle. The lower links will be parallel outside the frame and below the axle centerline, and the upper link will be a triangulated link above the center of the housing and between the frame rails. Anyone have any suggestions?
1954 3100 Nova Subframe, Pontiac Posi, roller for now1967 C-10 SWB 350/350/Posi. Soon to be Crew Cab!
1978 Crew Cab Dually roller
1982 C-30 Rollback, 454, 4 speed
2004 K1500 Suburban Z71 5.3 Kid Mover
6 Door King is offline   Reply With Quote
Old 07-16-2011, 02:29 PM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: Calling Guys that Tow!
Make sure the setup you use has independent valves for each bag, or sway will be hard to control.
Dunenutt is offline   Reply With Quote
Old 07-16-2011, 04:15 PM   #3
6 Door King
Thank you for the suggestion, that was one aspect I had debated. It had not crossed my mind, but open air going between the two rear bags would only make the sway worse and would probably send me off the road.
Old 07-16-2011, 05:15 PM   #4
SCOTI
SCOTI's Avatar
A 4-bar set-up like described would offer the best ride vs. load capacity. The link bars outside the rails will allow for a nice sturdy platform if the bags are placed as close to the rails as possible.
What size truck to be specific?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-20-2011, 06:21 PM   #5
craig@ridetech.com
Formerly LSC71
If it was me, and I was going to do any serious towing or hauling I would go with a parallel style 4-link with panhard bar or a true triangulated 4 link where there are 2 separate upper bars that angle from the axle to the frame. A "wishbone" upper I don't feel will offer enough side to side support under a heavy load, you will most likely feel the rear "walk" from side to side as the single connection at the point of the wishbone is trying to keep the axle centered. Other than that yes, definitely have the supply separated going to each air spring and use good quality shocks. We've towed trailers here for many hundreds of thousands of miles with out fail. They ride great loaded or unloaded, plus since you can raise and lower the rear it makes hooking up a trailer much easier on the arms. Not so much cranking up and down
craig@ridetech.com is offline   Reply With Quote
