Old 04-04-2003, 07:17 PM   #1
johnw67
ididit sterring
has any one used a ididit tilt.
my truck is a 67 and i need to know which one i need .there are 4 different sizes.
johnw67 is offline   Reply With Quote
Old 04-05-2003, 12:03 AM   #2
KEH
Better late than never
KEH's Avatar
I bought a steel tilt 35" from them 10 years ago. I haven't installed it yet, but I'm close. You will need a flat harness connector that replaces your stock harness connector to the column. You can buy from them, I got mine off early 70's truck & spliced. Also the new column shaft is 1" (I think) so you will need to change your rag joint too. And the shaft between gearbox & column, I got a longer one from the parts yard because my stock was too short.
I should be doing my install soon. Let me know if I can help.
Ken
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 04-05-2003, 07:51 AM   #3
72ChevyCheyenne
72ChevyCheyenne's Avatar
I just bought the chrome one for my truck. The only thing I have to do is dish out the shaft on the column to accept the bolt on the intermediate shaft coupling. Mine is a 72. Here is what I copied off their web site.
1967 GM Truck
The 1967 trucks were produced several different ways, the installation may be like the '62-'66 model, or like the '68-'72 model, depending on when it was produced. While installation may be different, the column is the same as the '68-'72 model. Accessories for the '62-'66 model may be necessary for the installation.
Steel Tilt Floor Shift: $299.00
Chromed Tilt Floor Shift: $399.00
Brushed or Polished Aluminum: $575.00
Steel Tilt Column Shift: $510.00
Chromed Tilt Column Shift: $640.00
Brushed or Polished Aluminum: $925.00
Mine also came with the wiring adaptor at no additional cost. I had to order the shift indicator seperate for $20.00.
Bill Durham
http://home.attbi.com/~bulldurham
72 Cheyenne
Restoration in progress
Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed.
72ChevyCheyenne is offline   Reply With Quote
Old 04-05-2003, 08:15 AM   #4
MOTHERTRUCKERS
Bill there is a stainless Borgenson joint available along with a stainless shaft that fits and looks great.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 04-05-2003, 08:30 AM   #5
72ChevyCheyenne
Not from Ididit. Flaming River has the shaft components.
Bill Durham
72 Cheyenne
Old 04-05-2003, 10:54 AM   #6
MOTHERTRUCKERS
Ya I guess I should have said that, with all their joints we have put in these trucks.
