Center link rubbing crossmember
1972 2wd. Why is my center link rubbing my crossmember? I had the crossmember off to clean and sandblast. I also replaced the pitman and idler arms. Now the link is rubbing against the front of the crossmember. I can't remember if there is some adjustment in the crossmember itself or if i got the wrong pitman/idlers.
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
Newbee
Re: Center link rubbing crossmember
Is it in backwards? Nuts for the tie rods face front. Pics may help.
Moderator
![]() Join Date: May 2007
Sounds like it is in backwards.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
tie rod nuts are facing the front....are the holes on the crossmember slotted for adjustment? I don't think the frame holes are slotted...
1992 Gmc 2wd 1972 Chevy Blazer 2wd Last edited by 72gmcshorty; 07-16-2011 at 06:41 PM. |
Newbee
if the upper a-arm bolt holes in the frame lined up, I would say it has to be the pittman/idler arms then.
Sorry, I should have said we had the front suspension completely torn apart. Now that its all together, the center link rubs the crossmember at the driver side and has about 1/8" clearance at the passenger side of crossmember. Looking at it, the pitman and idler arms are the only thing that controls where the center link sits.
laying low
![]() Join Date: Mar 2001
There are different part numbers for standard and power steering parts from 67-72 and 73 up. There is no adjustment for the crossmember so your prob is in the new parts you've used. I suggest check the part numbers and applications where you bought them.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
i got all the parts from Early classic in their rebuild kit. Would the fact that i have dropped spindles be a problem?
* Could a mod please move this thread to the suspension forum *
Take some pics of your set-up & post them. This will prob help identify any potential issues.
you can see in the one pic that the bar angles toward the driver side of the cross member
My pitman arm measures 5 1/4 center to center.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#13 |
anything looking out of place?
#14 |
The drag-link should be parallel all the way across. Something is either tweaked or is the incorrect length.
If there's no indication of either frame rail being hit & all the idler mounting holes look correct, I would focus on the parts that are new. Since these parts were replaced, it's possible the length of one or the other isn't correct. Also, you mentioned the x-member was removed for clean-up. While the holes don't allow for a lot of play, I do recall there is some there. I would check the x-member to make sure it's square within the rails. Some simple diagonal measurements from fixed points on the rails to similar points on the x-member should give you an idea.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-20-2011 at 01:14 PM. |
#15 |
Chiming in...I have a similar problem on my 69, except my center link rubs all the way across. No new parts, no damaged frame. I gave up on mine a while back.
69 C10 SWB LY6 T56 70 Chevelle SS 396 4spd |
#16 |
If it rubs all the way across, it's usually installed backwards (an easy mistake). Which direction are the castle nuts that secure the tie-rods to the center-link facing (to the front or rear)?
#17 |
Nope, its installed in the correct orientation
#18 |
Something has been changed then. They don't rub from the factory so something has been changed along the way or removed/re-installed incorrectly.
#19 |
Heres my thread when I looked into the issue
http://67-72chevytrucks.com/vboard/s...d.php?t=438119 Truck is still that way as I gave up. I purchased a new frame that I have modified and will be swapping the body and suspension over to eventually. That frame had manual steering installed and did not have the rubbing issue.
#20 |
is there a pic of how it's supposed to look? How much gap is there supposed to be between the center link and the cross member?
#21 |
About .500" or so gap.
#22 |
is 5 1/4" the correct center to center distance for the pitman arm?
#23 |
What does you pitman measure? That is the measurement on my 72 with power steering. Just trying to give you something to look at.
#24 |
my truck is at the bodyman's. Just trying to get all the info before i go there.
#25 |
on my rolling frame with manual steering it was about a 1/4"
