Auto trans to manual trans
I just drove my buddy's 71 SS nova with a M22 in her and now I'm ruined. The TH400 that i have in my truck is just not the same.
So my question is how hard or easy is it going to be to put a 5 or 6 speed mt in? And what kind of transmission would be a good choice. The ones online that i have found are only good for 400 to 450 ft/lb torque, I have a 468 11:1 flat tapped cam that puts out a round 550 hp Any suggestions or thoughts would be greatly appreciated Thanks Bobby |
Re: Auto trans to manual trans
Might be a bit big, but a NV4500 would probably take it.
Is the NV4500 a truck for car transmission?
I want to take the truck on the strip too. i was looking at the m22 as a posabilty. But i want OD or duble OD. This is what i found http://www.hurst-drivelines.com/inde...04&Itemid=155# Let me know thanks Bobby |
![]() Join Date: Jul 2010
Aftermarkert 5 or 6 is what you wanna use..google TKO 500/600
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
Thanks guys
Now I have a low hump floor. Will I need a high hump for the 5 or 6 speed? I did read some where that the bench seat might get in the way. Is this true? |
2WD Jimmy
![]() Join Date: Mar 2005
I have a tko600 in mine. I put in a high hump pan, but a low hump might have done it. If you are going to race it, I would definately go with the 600... it wil live.
Did u use the stock mechanical clutch or did u go with a hydraulic one? i can't find an aftermarket bell housing to fit a mechanical style clutch
